R50/53 Operating temperature of engine -- Guys with ultraguages and scan gauges some help...
Hi Guys,
So today while driving to work I smelled the sweet smell of coolant -turns out my cap was likely leaking and I had coolant coming out from under it -- granted its supposed to vent so maybe there is another issue.
So coming home tonight I flipped my scan-gauge over to Water temp to monitor it. Driving on the highway my temp was between 198-202 when cruising. Slowed down for city traffic and (NYC) and watched the temp creep up to 215. Put the car in a parking spot and watched the temp climb slowly to 230 -- then the loud fan kicked in and the temp dropped pretty rapidly to 215. I had to go inside so I shut it down.
Questions -- what is the normal operating temperature you guys are seeing while cruising and while in slower traffic.
Does the thermostat and high speed fan kick in at 230 degrees which would explain the rapid drop off in temp?
Thank you all for your help.
I'll be ordering up a new DORMAN fan -- realistically how long is this going to take for me to put in: I am going up to my friends place in a few weeks -- might take some time in his garage to do some work (oil change, crank pulley etc..) -- looks like this might be something for the list too.
Greek -- I was seeing 230 while parked after driving for about 25 minutes -- mind taking a look tomorrow, letting it idle a little before shutting it down?
Hey guys I did find the following information in a different post which fits exactly with what I witnessed.
https://www.northamericanmotoring.co...placement.html
Post #5 states:
"Just Finished this...not too bad. I also purchased the Dorman fan from Amazon. Mine had two connectors.....the original on the car had one. I've learned (ZippyNH) that is kinda like an Appendix from the earlier cars and not used any more (the smaller of the two)
While researching this fix I came accross some incorrect numbers on when the fans (low and high) are actuated. I'm getting this right out of the Bentley Manual:
Low: Comes ON @ 221F and shuts off @ 214F
High: Comes ON @ 234F and reverts to low speed after dropping 7 degrees.
AC and Fan action:
"The cooling fan operates on low speed when the A/C is switched on AND the system pressure reaches 8 bar. The fan switches to high speed should the AC system pressure rise above 18 bar."
This would explain why some people DO NOT get the fan upon immediately turning on the AC.
And I'd like to ask a question also. Since I had coolant blow up all over the engine how long will that smell stay so I can smell a new leak?
Joe in Warner, NH"
Post #5 states:
AC and Fan action:
Joe in Warner, NH"
yea ill take a look and see what the temps look like after a long drive tomorrow. but i have never ever seen it go above 210 even when im beating the **** out of it on some back mountain roads.
With my stock ECU my car never saw past 195 even at highway speeds...
After a tune, and a coolant change (added some water to the mix), my temps go from 193-200 at highway speeds, never seen past 195 in the city.
The fan change isn't too bad, if you need any help feel free to PM me, I had to do it twice... (I thought the replacement fan was broken, turned out to be the AC compressor -.-)
I run a ScanGauge II, and live in South Florida (it's not really been hot here yet). My temps are always 200+, typically between 205 and 215. MINI engines are known to run hot, and the theory is that this is why they do not put a temp gauge in the cars as standard equipment (it would scare some people off).
I'm in Florida also and I see 187-198 as normal rarely above 205 sitting in traffic. Mine does cool down quickly as soon as I start to move but I do have a Mishimoto radiator also.
Not sure if you have a gen1 or gen 2 mini so migh be different.
On my gen1 there was a wiring harness that came from the fan and across the front of the radiator to the driver side and hen there was a connection.
If you disconnect there you can test the prob. Mine had 3 leads. One for ground, one for low and one for high.
I used the leads from a multimeter and jumped from battery and to ground and low. If the fan runs then it is not the fan but the resistor for the fan.
There is a huge thread here about that issue. I opted to by a replacement resistor and spliced it inline in front of radiator to fix the prob.
The oem solution will fail because the resistor is on the backside of the fan and does not get enough air and burns up.
Found this hack was a lot cheaper and quicker.
Just off hand can you take a pic or show the step by step of splicing in the resistor mod?
I did a reading while driving to work today did not go over 209...went between 198-209...same drive actually longer.
Wondering if yesterday was a fluke...I don't doubt my low speed fan is done though
myabe you have sticky thermostat, i had a fluke problem once in my jetta i was driving to the autozone to get something and when i park i notice the temp needle was like 3/4 up i was like WTF is goning on now. went in got my stuff and went to leave temp went back to normal and i am pretty sure it was the T-stat. never happend again.
Hi...I have a gen 1- have read a lot about the resistor issue and if replacing the resistor or splicing in is the same work as replacing the fan would rather just replace the fan.
Oh well -- sucks but I guess I'll be pulling that Fan out of there at some point. The only saving grace is I LOVE air conditioning and basically use it when temps get into the 70s....my drive to work is 95% highway where I am flowing constant air across the radiator.
The sad part I live in NYC and have absolutely no place to take the front bumper off of the car -- shockingly parts stores don't like you working on your car in their driveway.
so this is going to have to wait until I can get to my friends place (4 hours away). the resistor mod does not work on the early style cars (I read the entire resistor mod post) -- my car is a 2003. I may order the dorman replacement resistor that goes on the fan itself and repair the fan so I have a spare lying around (we have a storage locker for a reason) - we are probably moving out of the city at the end of the year so I guess I'll be changing out things then.
Hey Greek -- so it looks like I have had no such luck -- today driving home it hit 230 again - the fan didn't kick on automatically fast enough for my liking so I clicked the AC on -- after about 35 seconds the temperature dropped down to about 205 degrees as the high speed fan turned over...
so this is going to have to wait until I can get to my friends place (4 hours away). the resistor mod does not work on the early style cars (I read the entire resistor mod post) -- my car is a 2003. I may order the dorman replacement resistor that goes on the fan itself and repair the fan so I have a spare lying around (we have a storage locker for a reason) - we are probably moving out of the city at the end of the year so I guess I'll be changing out things then.Had that been around when I did mine on my R50 I would have bought it.
With MOTD being next week, you may want to order this tomorrow before Chad and crew back up for the Dragon.
silence2-38554
98
Sep 21, 2016 02:52 PM
PSIChocolate
Aug 13, 2015 12:46 PM
