Drivetrain Looking for a detailed how-to for 15% pulley install
Old Apr 23, 2013 | 04:02 PM
patsum's Avatar
patsum
hey everyone.
I have a 2003 cooper S with 128,000 miles on her! Love the car.
I just bought the alta 15% pulley and already have colder running spark plugs and a CAI installed.
I am NOT mechanically inclined at all so I usually have my buddies at a shop down the road do this work. The issue is while they have the tools, they do not have much mini experience... but they are all I can afford labor wise
I am looking for a good guide on how to change out the pulley and the belt for an R53
Thanks!
Old Apr 23, 2013 | 04:19 PM
Braminator's Avatar
Braminator
Here you go. I hope you have a pulley remover.
http://www.promini.com/technical/PulleyInstructions.pdf
Old Apr 23, 2013 | 06:07 PM
Da_Ghost's Avatar
Da_Ghost
The ''hardest'' part is removing the pulley, the rest is just removing a bunch of bolts, intake, motor mount, etc, and jacking the engine up so the stock pulley shows its ugly face. Like Braminator said, hope you have a proper puller for our pulleys. Rent one, borrow one or buy one, but it's a must have and it will make things a lot easier. Some here tried taking it off with a standard puller and ended up having to cut what remained of the pulley to get it off.
That's the one I've used and it worked like a charm: http://www.outmotoring.com/mini-coop...oval_tool.html
On a side note: If you love your car now, wait once you have the pulley :p
Old Apr 23, 2013 | 08:09 PM
ZippyNH's Avatar
ZippyNH
Alta also has a how-to.
As said above, a mini specfic puller is needed....
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
