TPMS error?
Old Apr 20, 2013 | 04:20 PM
Nalublue's Avatar
Nalublue
TPMS error?
I just got back from a week long vacation. on my way to pickup my dog at a friend's house I get the alarm that my front left tire has low pressure. It came up after a short distance, maybe 2-3 houses down the road.
I got back from my friend's house (less than 2 miles) and checked the pressure and it was 32 psi! I also checked the rear left and it was 33.5. from what the owners manual it looks like the TPMS bases a fault on rotation distance between other tires. Could 1.5 psi cause the alarm? I didn't check the other tires (I'm tired and jet lagged!)
Do I have a problem or should I just reset? Is my Countryman mad at me for leaving it? (I did miss it a lot!)
Thanks in advance!
Old Apr 20, 2013 | 04:31 PM
Braminator's Avatar
Braminator
It was mad at you for leaving it. Check your door sticker for tire pressure and check all 4. Make sure they are all even. Then reset the light and you should be good.
Old Apr 20, 2013 | 04:56 PM
Nalublue's Avatar
Nalublue
Great! I feel relieved. I'm glad I don't have to pony up the bucks for a new run flat.
My tire caps have N2 on them. Can I add regular gas station air or should I get more Nitrogen somewhere?
Old Apr 20, 2013 | 05:01 PM
Braminator's Avatar
Braminator
Yes you can go anywhere and get air. No worries.
Old Apr 20, 2013 | 05:08 PM
bmwr606's Avatar
bmwr606
your countryman has pressure sensors inside the tires ... it is not rotation based, but actually reads the pressure and alarms on a pressure change
all tires do not have to be at the same pressure, i run 5 psi more in the fronts than the rears and have run upto 10 psi differential
scott
Old Apr 20, 2013 | 05:13 PM
Braminator's Avatar
Braminator
They still have to be above the threshold of the sensors.
Old Apr 21, 2013 | 10:55 AM
Nalublue's Avatar
Nalublue
My Mini and I are happy again. thanks for your quick help!
freckles81
Jan 15, 2017 06:33 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
dutchhome
Sep 30, 2015 07:17 AM
ericf1993
Sep 26, 2015 03:58 PM
renchjeep
Sep 6, 2015 01:54 PM
