R55 Radar Detector Mounting
Old Apr 19, 2013 | 10:45 AM
Vegasbaby's Avatar
Vegasbaby
Anyone have a Radar Detector in their Clubman?
I'm thinking of going with a cordless model and mounting on top of rear view mirror.
I attached a pic of my mirror as there are a few varieties out there.
If anyone has advice or a similar setup attach a pic.
Old Apr 19, 2013 | 11:20 AM
RobertJ's Avatar
RobertJ
Cordless detectors are not as effective as corded ones. You can tap power from the area pictured in your photo. I don't know the specifics, but there's a thread on it here if you search. It's how I hard wired my Valentine 1, and it works perfectly. Then I just used suction cups and mounted to the driver's side just above the miror. I'll snap a pic and post it if you're interested.
Old Apr 19, 2013 | 12:13 PM
6thGear's Avatar
6thGear
^ ive got the same setup
Old Apr 19, 2013 | 12:38 PM
Vegasbaby's Avatar
Vegasbaby
Snap a pic if you could. I'd like to see how it sits.
Old Apr 19, 2013 | 01:04 PM
phoxx47's Avatar
phoxx47
I have been very pleased with my cordless escort - I use a non-skid sticky pad, the kind that's made for a smart phone and put it on the dash. Allows me to grab the detector and conceal it whenever I feel it might be exposed to theft.
Old Apr 19, 2013 | 01:22 PM
bratling's Avatar
bratling
Super Moderator
Same deal here. V1, hardwire power adapter tapping the power to the light cluster. Turns on with the car. Suction cupped to the windshield to give it a good view.
(No point handicapping it by sticking it up inside the plastic, behind the metal roofline!)
And like he said, cordless detectors will not be as effective. To maintain their battery life, they cycle on and off. This slows their response time. If you are serious about maximizing your chances vs the police, do yourself a favor and spend the dough on a Valentine 1.
Old Apr 19, 2013 | 01:47 PM
6thGear's Avatar
6thGear
here you go. Even though the detector looks like it sits low on the windshield, it is not blocking my view when I am driving (im 5'10"). The reason why the radar detector is not closer to the mirror is because there are black dots on the windshield glass and the suction cups wont work. I checked the clearence right above the left side of the mirror and it is a tight fit. It looks good there and there is good forward exposure for the detector, but I do not know how you would attach the radar detector.
Old Apr 19, 2013 | 03:38 PM
RobertJ's Avatar
RobertJ
^^^^ That's exactly how mine is setup.
Old Apr 19, 2013 | 03:56 PM
astroBlackMetallic_Mini's Avatar
get one of these
http://www.ebay.com/itm/MirrorMount-...-/190815563640
Old Apr 19, 2013 | 04:12 PM
Vegasbaby's Avatar
Vegasbaby
^ How does that work on the Mini Mirror? ^
Old Apr 19, 2013 | 04:38 PM
ya, i guess good point... if your mirror is like my mirror (R53), there is some room between the large plastic piece and the mirror itself... but that piece does not nec look like its long enough to fit over the large plastic bit.
you might have to go with just the windshield suction cup thing. i didnt like that however, because then i couldnt put up my sun shades!
so i mounted mine to the top of my gauge cluster on my dash...
Old Apr 19, 2013 | 05:43 PM
Vegasbaby's Avatar
Vegasbaby
That's a sweet gauge set up! What are they?
Is it ok to obstruct that air vent?
Old Apr 19, 2013 | 05:48 PM
Oil temp and oil pressure.
If you look close, you'll notice an air vent in the middle pod! I chopped up an OEM vent and glued it in place. So, instead of pointlessly shooting air into the windshield, it blows more or less in my face!
Old Apr 21, 2013 | 03:56 AM
bratling's Avatar
bratling
Super Moderator
Snapped a couple pics of my setup for OP:
Driver's view:
Outside view:
It's out of my way, but still close enough I can reach up and hit the mute button. The display remains visible to me even when I fold down the sun visor.
Sent from my iPad using NAMotoring
Old Apr 21, 2013 | 07:21 AM
Vegasbaby's Avatar
Vegasbaby
^ That's exactly what I was looking to do. ^
It's not awkward at all.
Old Apr 21, 2013 | 09:32 AM
Minian's Avatar
Minian
Driver's view:
Attachment 74097
Outside view:
Attachment 74098
That is how my mini is set up. I didn't even splice any wires.
On the R53 within the upper light console are hole locations where the wires are soldered in. I just used and extra cord and stuck the wires in the correct holes. That was a year ago, and after rocks, bumps, and pot holes it has never failed.
Old Apr 21, 2013 | 09:34 PM
6thGear's Avatar
6thGear
I guess you are lucky that you dont have any black dots behind the mirror so you can mount closer to the center line like you have.
Driver's view:
Attachment 74097
Outside view:
Attachment 74098
Old Apr 21, 2013 | 09:53 PM
Minian's Avatar
Minian
^I have black dots behind the mirror. the suction cups are still working over them.^
Filmy
15
Jun 6, 2023 06:27 AM
elverado
Jan 18, 2022 02:51 AM
minimofo
Sep 30, 2015 12:26 AM
caiken
Sep 7, 2015 09:10 PM
Sep 4, 2015 02:34 PM
