R56 1101S Subwoofer Issue I Need Help
Old Apr 15, 2013 | 04:15 PM
AndrewFarley96's Avatar
AndrewFarley96
I recently installed the subwoofer into my 09 cooper. I have the gain set at about 90% and it is on low pass. My issues is that it is causing my front speakers to distort/clip. It has even shut the entire system down. The Head unit still says it is playing the music but nothing from the speakers. It takes about 20 Minutes before it comes back on. It doesn't do this will every song. I can not figure it out. I have check all of my wiring and it is all correct. Also the head unit is stock. Any information would be helpful
Old Apr 16, 2013 | 08:36 AM
white3's Avatar
white3
Contact Kevin at Integral Audio. He is a great guy and will figure out the problem for you.
Old Apr 16, 2013 | 11:48 AM
AndrewFarley96
I did contact Kevin. He said that the Sub is not connect to the front speakers. But I still am having the issue only when the swub is hooked up.
Old Apr 17, 2013 | 08:16 AM
Summons's Avatar
Summons
As I remember it, the sub is powered off the same amp as the door speakers - just the rears remain powered by the head unit. Turn the base down on the head unit, bring up the level on the sub (that dial IA suggests putting in the tray in front of the shifter), and turn the volume DOWN in general!
I too am able to distort the fronts, but to do so, I do have to push the volume louder than good for my already damaged ears...
Good luck...
E
12 MCS IA SS w sub
Old Apr 17, 2013 | 09:31 AM
richardsperry's Avatar
richardsperry
I'd bet you don't have it installed correctly. Especially where the sub input leads connect to the car harness.
Casrio
Apr 20, 2021 01:52 AM
battlehawk_mini
Mar 5, 2021 06:15 AM
rtk90
Aug 29, 2019 09:08 AM
tylewis
Sep 6, 2015 01:07 PM
SunnySideUp
11
Aug 26, 2015 06:42 AM
