Suspension Control arm bushings will not slide on!
Old Apr 14, 2013 | 03:48 PM
bodinski's Avatar
bodinski
Lowered the sub frame a little, pried the old rotten bushings out, and am finding it impossible to slide the new, pre-pressed oem bushings onto the control arm shafts. Anybody got a trick to share?
TIA!
bo
Old Apr 14, 2013 | 04:34 PM
Da_Ghost's Avatar
Da_Ghost
Don't know about the oem bushings, but after installing the Powerflex ones, it slided right on the control arm shafts :s Did you tried using lube on the shafts? If this can help, the article does state that BMW say that there's a tool required for this, but using lube and a hammer should do it: http://www.pelicanparts.com/techarti...eplacement.htm
Old Apr 14, 2013 | 04:50 PM
valvashon's Avatar
valvashon
Consider yourself lucky. This is your cue to return the OEM ones and get a set of Powerflex ones so you don't ever have to do the job again.
I did notice when I took my cracked OEM ones off, quite a bit of the old rubber stayed behind on the control arm. Make sure that is all off- you want to get down to the roughly hexagonal shaped metal piece.
Val
Old Apr 14, 2013 | 05:53 PM
bodinski's Avatar
bodinski
I got all of the old ones off. I've used lube & a hammer but there isn't much room to get a swing going, I managed to get the pass. side about halfway on by prying creatively, but it's stuck.
They could have easily put threads in the hole in the end of the shaft so you could just run the thing on with a bolt & washer.
Old Apr 14, 2013 | 11:33 PM
Eric_Rowland's Avatar
Eric_Rowland
Eek. You're scaring me and my pre-pressed OEM bushings.
Old Apr 15, 2013 | 12:36 AM
esfreerider's Avatar
esfreerider
Val
This OR a bigger hammer but preferably powerflex
Old Apr 15, 2013 | 05:44 AM
bodinski's Avatar
bodinski
There is no room for a bigger hammer. I chose the stockers due to time & budget constraints. I hate it when a simple plan backfires. I'm going to see about renting an impact hammer.
Old Apr 15, 2013 | 06:11 AM
minsanity's Avatar
minsanity
Remove the subframe & you won't need any hammering. Short cuts sometimes aren't worth it unless you've tried them time & again. Remember, MINIs are best taking the longer route!
Old Apr 22, 2013 | 06:09 PM
herbie_53_guy's Avatar
herbie_53_guy
i'll second the power flex, but if you have o stick with OEM, spray down the the control arm with an aerosol glass cleaner.
Old May 1, 2013 | 06:41 PM
bodinski's Avatar
bodinski
I decided to go Powerflex an am very pleased with them! Getting the rear bolts in was a chore. I actually ground just a little of the metal away at the front of the pass. rear bolt hole, making the install much easier.
patsum
26
May 29, 2021 06:29 PM
minimofo
Sep 30, 2015 12:26 AM
Gen1Parts
Sep 7, 2015 03:50 PM
yukinoinu
Sep 7, 2015 02:46 PM
Gen1Parts
Sep 7, 2015 01:37 PM
