R50/53 Check Original ECU software
Old Apr 14, 2013 | 01:59 PM
Nicolai Juhl Bendt's Avatar
Nicolai Juhl Bendt
I bought a 2003 mini cooper s a month ago. It was sold as a normal mini cooper s with 163 HP, but after a run on a dyno it showed following results:
Engine Hp: 195
Wheel Hp: 140
Loss in transmission : 55 hp
So do you guys know if that is normal, and is it possible to check if it is the origial ECU without taking it to the shop?
And is it normal with such an amount of power loss in the transmission?
- Nicolai
Old Apr 15, 2013 | 10:45 AM
Tab32's Avatar
Tab32
Is it automatic or manual?
Old Apr 15, 2013 | 11:33 AM
Nicolai Juhl Bendt
Sorry forgot to write that.. It is 6 speed Manual gearbox
Old Apr 15, 2013 | 12:10 PM
Braminator's Avatar
Braminator
Engine Hp: 195
How did you come up with this number?
Old Apr 15, 2013 | 12:14 PM
Nicolai Juhl Bendt
From the dyno print out:
Old Apr 15, 2013 | 12:17 PM
ZippyNH's Avatar
ZippyNH
I'm curious too....
unless you took the ENGINE OUT, and connected the crank to a dyno, that number is just a "estimate" based upon "typical" losses to the drivetrain, Alternator. A/C, friction losses, etc.
163 HP rated...
Wheel Hp: 140 on the dyno
Seems pretty good for a stock 10+ year old car if the dyno #'s are accurate.
Braminator's Avatar
Braminator
Something is not right. You will lose about 15% thru the drive train but not 30+%. So I think their Dyno reading for the engine is BS.
Old Apr 15, 2013 | 12:35 PM
Nicolai Juhl Bendt
Ok, think i will go and get an test another place to compare the two.. Could it be possible that something is wrong in the drive train.. worn out clutch, bad gearbox etc..?
Old Apr 15, 2013 | 12:46 PM
ZippyNH's Avatar
ZippyNH
LIKE I SAID...IT IS A BEST GUESS...bet they added about 20 HP to the "engine output" to account for the SC...Hense the Higher than typical report.
Sure in some ways, this MIGHT be true...but not typicaly reported.
blackie
Sep 2, 2015 09:16 PM
Aug 21, 2015 11:18 AM
Mini'mon
Aug 16, 2015 04:15 PM
bugeye1031
Aug 15, 2015 08:14 AM
Dashdog
Aug 10, 2015 06:17 AM
