GP Rear Spoiler
Old Apr 9, 2013 | 03:55 PM
kfmuller's Avatar
kfmuller
GP Rear Spoiler
Have any of the new owners taken a good look at their rear spoilers? How does it attach around the glass?
If someone could take a picture, or two or three, I'd really appreciate it.
Just want to see if it's possible to add one, but keep the current back glass on my JCW.
Lot's of info says you have to buy the kit with the back glass, but I've seen pictures of the early mules, and they've got rear wipers, etc.
Old Apr 9, 2013 | 05:43 PM
cct1's Avatar
cct1
There are two companies that make a GP style rear wing, neither of which require removal of the rear glass: Fubrication, and Orranje. I have the Orranje wing, and they recently started making them adjustable, it's a good piece, but the Fubrication wing looks great too.
If it's cosmetic, up slightly above the roof line looks best. If it's function, it needs to go slightly below--doesn't look as nice, but if you look at the wind tunnel video of the new GP, you can see why they lowered it about an inch.
Old Apr 9, 2013 | 06:29 PM
MinMin2010's Avatar
MinMin2010
The GP rear wing does require you to buy the glass. It has a proprietary mounting system that incorporates the mount with the glass. I had a really good look at it this morning after my MA mentioned it. Save yourself some money and buy the aftermarket ones. The OEM MINI GP wing will set you back $2K. I think Fubrucation has theirs for around $600.
Old Apr 10, 2013 | 05:30 PM
kfmuller's Avatar
kfmuller
Went by the dealer to take a look at the GP today. Very nice. Took a very good look at the spoiler, and it really doesn't look like I need to do the glass, too. I know that's what the MINI Genuine Parts UK website says, but it appears to be an easy swap. And, the spoiler really looks fantastic live. Very nice.
Old Apr 10, 2013 | 08:01 PM
Airborne Ranger's Avatar
Airborne Ranger
Hey KF.
I took a good look at it just now and took a few pics- doesnt appear to have any special glass at all with regards to the spoiler. The GP does have a different glass than a standard R56 because of the rear wiper delete... maybe that is where the GP specific glass hooplah comes from?
It looks like the side uprights have a clamping system that has 2 torx bolts that pinch a "U" channel sleeve that secure them to the glass.
I did notice that the top fascia is contoured to incorporate the rear spoiler- probably something that the aftermarket kits do not offer...
hope this helps.
good luck.
Old Apr 10, 2013 | 09:29 PM
willieboy's Avatar
willieboy
You are correct. You will need the glass and he spoiler. Good friend of mine just did it on his new JCW Hardtop.
GP1257.
Old Apr 20, 2013 | 09:14 AM
Airborne Ranger
GP1257.
As I thought- this is untrue. I removed my spoiler to get the facts rather than rely on heresay.
The spoiler supports mount to the glass using a removable "C" channel bracket. The top secures to the roof just as a standard spoiler would mount- to the hatch using 5 10mm nuts.
Pictures are worth a thousand words so here we go:
removed these 4 torx nuts first- two per side:
remove the rubber caps to get to the 10mm nuts
here it is off the car:
side/upright support brackets
mini decal for reference:
hope this helps
Old Apr 20, 2013 | 10:31 AM
andywong33's Avatar
andywong33
So which means the GP2 spoiler can be placed on a non GP mini without buying the rear glass, assuming if someone sells the spoiler and side brackets only.
Old Apr 20, 2013 | 11:17 AM
Airborne Ranger
exactly
Old Apr 20, 2013 | 04:08 PM
teamrodney's Avatar
teamrodney
I'm sure these people in the UK ( minigenuineparts.co.uk ) would be able to help if no one in the US can. I see they are offering the spoiler with the rear glass at a huge price, but the spoiler alone should be obtainable.
Still, I reckon Outmotoring could source it if requested.
Old Apr 20, 2013 | 05:23 PM
kfmuller's Avatar
kfmuller
I can get the rear spoiler from my dealer. The issue I have are the little metal flange things that are taped or glued on to the glass and part of that strip in the pictures above.
It's not special glass, but if MINI won't sell those things separately, then buying the rear glass maybe the only way to get them. I can't seem to find a part no. for those pieces. They are the ones in the 2nd and 3rd pictures from the end above.
Old Apr 20, 2013 | 05:25 PM
willieboy's Avatar
willieboy
Guess my bud bought more than he needed then. I won't tell him. No need to crap him out. I was going on what he did. Sorry I was mis-informed.
GP1257.
Old Apr 20, 2013 | 06:33 PM
M'Cooper's Avatar
M'Cooper
I do like the oem GP wing, it looks great! If this stands true that the rear glass is not needed I would like to get the oem one instead of the aftermarket ones.
Im hoping those 2 brackets for the side of the glass are available without the glass.
Old Apr 21, 2013 | 06:47 AM
Rotherd31's Avatar
Rotherd31
I had the JCW CF wing on my 2012 MCS and ended up selling it a while back. Just not happy with the look. It was a straight up install, exactly like the photos show the GP2 wing in this thread. When I saw the GP wing I was in love! Far be it for me to let a little money stand in the way of getting what I want for my car! Saw the red-stripe JCW R-113 wheels and bought them a year ago and mounted them up to Michelin SS's for my summer wheel/tire combo.
I should know the answers to some of these questions within a week or so. I ordered the GP2 wing last week from my dealer. Coming from Germany and should be stateside sometime this week and then has to be shipped to my home in Michigan. Part# 51627341933. I doubt it will come with the C-channel mounting brackets. I ordered up some 3M commercial 1/2 wide double sided tape for mounting automotive exterior trim pieces. My intent is to run a strip on either edge of the rear glass the same length as the C-channel to rest the supports onto. I don't see that attachment point as being critical to the install, as with speed, the wing would exert downward pressure to the supports pushing them tighter onto the back glass surface. I've also sourced a company in Michigan that makes plastic fill caps for many different sizes of access holes. Once I have the wing, I will measure the diameter of the support bolt holes and buy four caps that will pop into the empty holes. More to follow when I get the wing.
Old Apr 21, 2013 | 07:27 AM
kfmuller's Avatar
kfmuller
That's great. Keep us updated. My dealer is ordering the rear spoiler for me tomorrow. It's in Germany, and I'll get an ETA next week on when it should get in. I like the double-sided tape idea. Figure we should be able to fashion something back there to mimic those metal flanges if we can't buy them separately from the glass. I want to keep my wiper.
Old Apr 21, 2013 | 10:33 AM
Rotherd31's Avatar
Rotherd31
Yep, keeping the rear wiper was also a priority with me too. My dealer said last week when I ordered, that there were eight in stock in Germany and that shipping time would be 10-14 days.
Old Apr 21, 2013 | 11:43 AM
kfmuller's Avatar
kfmuller
Keep us updated on your success at fashioning something for those flange things. I really don't want to buy the rear glass just to remove those things and put them on my rear glass.
Old Apr 21, 2013 | 07:56 PM
Rotherd31's Avatar
Rotherd31
Yep, same with me. The Braminator is working on seeing if the mounting brackets are available without buying the rear glass. Keep your fingers crossed!
Old Apr 21, 2013 | 09:07 PM
Mike@Tech Division's Avatar
Mike@Tech Division
This confirms what I was thinking based off some other pics I saw. The idea I've been toying with is making a mounting bracket that runs over the glass like the oem, but mounts to the inside of the hatch like the aftermarket spoilers. This would eliminate the need to even remove the glass at all and allow the use of the oem spoiler which I think looks much better then the aftermarket ones who's design is still based on the GP1.
Old Apr 22, 2013 | 01:40 AM
Tweedbean's Avatar
Tweedbean
If I was you I would save your money and go for an aftermarket one like the Orranje G-Wing, its probably not even a 1/4 of the cost of the genuine part, but looks just as good. They are also finishing off the work on an adjustable version too.
http://www.minitorque.com/forum/f754...260-p-p-29407/
Theres no need to change the rear glass, unlike some of the other replicas and the 1st gen original, their wing was designed to fit around the standard glass.
Old Apr 22, 2013 | 03:45 AM
Rotherd31's Avatar
Rotherd31
Hey Mike: Why not just duplicate the OE mounting bracket that slides over the edge of the glass? Unless I am missing something, I don't see the need to have it mount to the inside of the hatch. All it has to do is ride over the edge of the glass to allow the support bolts to go through the holes and thread to the support.
Old Apr 22, 2013 | 04:50 AM
Tweedbean's Avatar
Tweedbean
On the Orranje wing, you dont need to remove or change the glass.
Old Apr 22, 2013 | 06:13 AM
Mike@Tech Division
It may be ok to mount it with an adhesive to the glass, but as precaution I would prefer not to.With the OEM bracket I am not sure how the load is transferred. It could be through the glass and it supports it just fine or it could be rigid enough to actually transfer it around the glass directly to the hatch. Since I dont know and the goal is to not buy glass I figured its just as easy to make a few more bends and mount to the hatch.
I've actually been considering this as my next alternative to OEM. It does look nice. My main reasons at least for wanting OEM is I like the look of the GP2 spoiler better then the aftermarket spoilers which seem to be modeled after the GP1 and IMO doesn't fit the R56 aesthetic as well. The other reason, and really the more important one, is the class I race in doesn't allow aftermarket aero. Although I may be able to get a replica past tech, I would rather just avoid any hassle and prevent my chances of a DQ.
Old Apr 26, 2013 | 09:32 AM
M'Cooper's Avatar
M'Cooper
If you guys don't mind me asking, what exactly is the price you have payed at the dealer for this wing?
Old Apr 26, 2013 | 09:59 AM
ra2fanatic's Avatar
ra2fanatic
I don't think anyone has ponied up for this wing just yet because of the mounting of the glass to the wing.
