Suspension KW1 Variant Coilover Question?
Old Apr 4, 2013 | 10:01 AM
BluPrynt78's Avatar
BluPrynt78
FYI, I did search for this and got impatient! So sorry if its been answered.
Will I need adjustable camber plates?
I'm already assuming I will need rear lower control arms but not up to par as far as what KW1's provide out of the box.
Thanks in advance NAM!
Old Apr 4, 2013 | 04:02 PM
ColinGreene's Avatar
ColinGreene
Yes you need camber plates, should you want them.
Old Apr 4, 2013 | 07:43 PM
BluPrynt78's Avatar
BluPrynt78
Thanks for the response. Most of the high end coilovers seem to come with the adjustable plates and I couldn't figure out if the KW1's came with.
Fixed or adjustable?
Old Apr 4, 2013 | 07:49 PM
ColinGreene
Kw V1s are not high end.
Fixed or adjustable is up to you like i said before.
depends on what your doing with the car.
Old Apr 4, 2013 | 08:30 PM
BluPrynt78's Avatar
BluPrynt78
Looking for a mild drop. Not looking to slam it. Maybe 1.5".
I just want something high in quality w/o spending a few G's. I'm not saying all of the lesser value coils are cheap or garbage but KW seems to hv a very good rep.
I guess I'm into a quality drop with dependability being on the top of my list. I hope this makes sense.
Old Apr 4, 2013 | 08:46 PM
ColinGreene
Unless your looking for handling and you just want to lower it why run camber plates.
Old Apr 5, 2013 | 07:25 AM
andyroo's Avatar
andyroo
I'd recommend the IE fixed camber plates. Improves ride and handling, durable, and cheap too.
For most cars I'd say stick with stock top mounts if you don't really need them, but the stock top mounts are total junk on the first gen Mini.
- andy
Old Apr 7, 2013 | 09:27 AM
BluPrynt78's Avatar
BluPrynt78
So for a DD is it safe to go with KW1's, H-Sport LCA's, and 22mm H&R Anti Sway?
I would like to add the fixed camber plates and top mount at a later time of course but funds are limited for now.
Again, my goal is to close wheel gap and improve handling but also keep dependability on the brands/parts I choose.
Old Apr 21, 2013 | 01:21 PM
tremperj's Avatar
tremperj
Sounds like a decent setup. Very close to mine, in fact. I have a 19mm H&R rear bar, and did spring for TSW camber plates. Might as well wait, get em, and install the whole lot at once. If you add camber plates later, you're gonna have to align it again. Do it once, do it right.
donniedarko
Oct 21, 2015 01:15 PM
molala
Oct 2, 2015 01:53 PM
rob76turbo
Sep 15, 2015 10:11 AM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Ryan Caballo
Sep 4, 2015 12:20 PM
