R50/53 Daignostic port not communicating..
Old Mar 17, 2013 | 07:34 PM
uromini's Avatar
uromini
Hi guys.. have searched and found a couple of pointers.. (fuses, ecu connectors etc) and have come up dry
2003 Cooper S.. failed emissions inspection cause the OBDII port wouldn't communicate..
Checked/ tested (with a BUS fuse tester) all fuses in both fuse boxes and all are good..
Checked the ECU connectors (both) to see if there were any bent pins and there aren't..
Battery hadn't been disconnected or gone dead in at least a year.. so assuming "monitors" were set.. haven't hooked up my scanner to verify
Need to get it inspected and this won't let me.. any help will be greatly appreciated.
pic of the lil guy!
will do a more formal intro soon
Old Mar 17, 2013 | 10:17 PM
astroBlackMetallic_Mini's Avatar
should be like, fuse F5 and F36 in the inner foot well... otherwise ???
Old Mar 18, 2013 | 04:55 AM
uromini's Avatar
uromini
Will physically pull them and look at them, but the fuse tester passed those 2.
Old Mar 18, 2013 | 10:15 AM
uromini's Avatar
uromini
physically pulled emm. they're fine
Old Mar 18, 2013 | 10:47 AM
Densmini's Avatar
Densmini
I've had this a couple of times. Here's what I did: disconnect the battery and wait a few seconds. Then touch the 2 cables together. Reconnect and retry your OBD communications. Good luck!
Old Mar 18, 2013 | 11:40 AM
uromini's Avatar
uromini
will try that tonight!
thanks
Old Mar 18, 2013 | 11:56 AM
Densmini's Avatar
Densmini
This may seem obvious, but don't short the battery terminals in any way. Just touch the cables to each other to completely discharge the system. This "hard reset" MAY just clear up your problem.
Old Mar 18, 2013 | 01:12 PM
uromini's Avatar
uromini
hahah yeah I gotchya.. I've done this before with other cars at the shop I work at.
Old Mar 19, 2013 | 11:31 AM
Densmini's Avatar
Densmini
ECSTuning made a good point in another post: older code readers may have a problem reading some newer cars. My Actron can read my '03 Mini, but not my '06 Mazda.
Old Mar 19, 2013 | 01:38 PM
uromini's Avatar
uromini
This was the state OBD2 connector for the SMOG/ Emissions test that wouldn't connect
Old Mar 19, 2013 | 06:07 PM
Densmini's Avatar
Densmini
Did the battery-cable trick prove unsuccessful?
Old Mar 20, 2013 | 04:25 AM
uromini's Avatar
uromini
wasn't able to get out to the garage.. doin it tonight
Old Mar 21, 2013 | 06:38 AM
Dextervw's Avatar
Dextervw
Good Luck with her!
Old Mar 23, 2013 | 08:56 AM
Densmini's Avatar
Densmini
So, any luck? We are all holding our breath!
Old Mar 24, 2013 | 04:47 PM
uromini's Avatar
uromini
Haha sorry.. replaced the power steering pump today and did the "hold the terminals together " trick when I disconnected the battery.. when I powered everything back up BINGO diag port works again.. funny the tire light was on and the triangle were too. (Rear tires were down to 25 lbs)
Bet they were sposed to be on before but cause of whatever glitch it had they weren't.
Than again for the help and tips!
Old Mar 24, 2013 | 05:43 PM
Densmini's Avatar
Densmini
Good result! Congrats!
Paul!
Electrical
16
Feb 18, 2025 06:29 AM
flpat73
Nov 2, 2015 06:38 PM
micromini234
Sep 30, 2015 07:36 PM
SneedSpeed
Sep 10, 2015 07:22 AM
Sep 2, 2015 11:15 AM
