R50/53 New R53 MCS owner - Maintenance Questions!
Old Mar 24, 2013 | 06:17 PM
jpinkerton's Avatar
jpinkerton
Well I recently purchased a 2006 MCS with 73k miles on it and I am getting ready to rip it apart and do a thorough tune-up on it before handing it over to the wife as her new daily driver.
I have been trying to conduct as much research as possible, but it is difficult bringing all of the sources together.
So, what recommendations does everyone have for me while I have the car pulled apart in the garage? There appears to be a leak of some sort by looking beneath the vehicle.
Here is a list of what I have planned: (Please provide any and all suggestions)
- Finding and correcting the leak by starting with the crank sensor o-ring
- Changing the engine oil/filter/drain plug (is changing the drain plug common practice? I am used to just changing the o-ring or washer on it, not the whole plug)
- Changing the supercharger fluid (does Mini have a preferred fluid? or is the GM stuff the norm)
- Changing the serpentine belt
- Possibly changing the main crank seal after closer inspection
- Inspecting the oil pan gasket
- Inspecting the power steering lines for leaks along with cleaning the fan and motor
- Possibly changing out the clutch while I have it all apart (still on the stock clutch at 73k miles, how much life is left on it?)
- There are a few other seals and gaskets that end up being changed with the removal of the charger that I plan on doing
Sorry for such a long post! I just want to have a one-and-done long overhaul so I can get the Mini back on the road before too long!
Please let me know if you have any other suggestions on what I should be looking at and what is common problem areas. Also, I have the mini madness strut plates on order already. The towers might have a slight mushroom (hard to tell), so I got the plates to be on the safe side in the future.
- Joe
W0TM8
Dec 19, 2019 07:50 AM
tr3y003
Oct 22, 2015 10:48 AM
minipopkart
Aug 13, 2015 05:22 AM
clintmeister
Aug 12, 2015 11:11 AM
nomar116
Aug 10, 2015 11:24 PM
