R50/53 Cant unlock door manually with key
Old Mar 15, 2013 | 06:02 AM
R53minime's Avatar
R53minime
Anybody know why I can not unlock the door manually with my key I insert the key into the lock and it won't turn at all both inside and out door handles work fine key fob unlocks and locks fine just cannot do it manually?
Old Mar 15, 2013 | 06:28 AM
Its seized probably, when you don't use the outside key lock for a while they get dirt and salt and tend to stick.
Apply some spray lube first. Use a spray lube with the little straw to reach into the keylock past the little flap. Soak it down. Then insert the key and work it back and forth. Be easy on it and it should turn after a while.
Hope that helps.
Old Mar 15, 2013 | 05:55 PM
R53minime's Avatar
R53minime
I have another problem I went to try my spare key to unlock the door to see if it worked manually and no luck but I tried it with the fob and it didn't work anyone now how to program a key for a 2004 mcs?
Old Mar 18, 2013 | 09:50 AM
So your Key fob will not unlock the door now? Were you able to spray the lock with grease and then try working it.
The hard plastic spare key looks like this.
R50 R53 Models. -7/2004
The older style key Fob can have the battery replaced:
Newer style is sealed unit. 7/2004- R50 R52 R53
As well as newer key fobs that have comfort access.
http://www.ecstuning.com/Search/Cr2032/ES9541/
If you have the older style ( pre 7/2004 ) key the battery can be replaced. With the above battery.
How to reprograms Gen 1 key fob is post #11
https://www.northamericanmotoring.co...m-key-fob.html
polotska
Aug 23, 2015 03:03 PM
coachvminis
Aug 17, 2015 01:42 PM
speedbird_1
Aug 15, 2015 04:44 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
