R50/53 Brake Rotor Replacement
Old Mar 12, 2013 | 03:11 PM
bad venge's Avatar
bad venge
What size is the Torx bolt that holds the rotor on on an 05 cooper S ?
Old Mar 12, 2013 | 03:31 PM
minibx's Avatar
minibx
T50 I think Mfg Part#07136772426
Old Mar 12, 2013 | 03:33 PM
minibx's Avatar
minibx
Actually it is T50
Old Mar 12, 2013 | 03:35 PM
Braminator's Avatar
Braminator
+1^
Old Mar 12, 2013 | 03:43 PM
Capt_bj's Avatar
Capt_bj
They are not Torx, they are use a 7mm allen heads (hex head) guide bolts. The brake rotor uses a T50 torx head though.
What????? What's 'they'
you trying to cornfuse someone?
Been doing MINI brakes for folks for 10 years now .... my TORX-50 bit is a lil worn!
{ah ha .... Bram cross edited with me . . .}
Getting that TORX out on a GEN1 can be a bit** .... if you want suggestions, PM me
Old Mar 12, 2013 | 04:58 PM
Braminator's Avatar
Braminator
CAptbj you got this before I had fixed it. I was answering someone else. Too funny. LMAO
Old Mar 12, 2013 | 05:02 PM
Braminator's Avatar
Braminator
Even if you read what I posted I was still correct.
Old Mar 12, 2013 | 05:21 PM
Braminator's Avatar
Braminator
Captbj are you going to the British car show next month?
Old Mar 12, 2013 | 07:23 PM
bad venge's Avatar
bad venge
the last time they were changed there was a good coat of never seize on new bolts to hopefully ease removing them this time
Old Mar 13, 2013 | 08:01 AM
toolmonger's Avatar
toolmonger
I'll say. I worked one on mine for a couple hours to no avail and ended up stripping the torx head.
So then I welded the torx bit right to the bolt head. Once that was done, I worked on it another half hour or so before accidentally twisting the head right off the bolt.
I should've used a torch to loosen, but was afraid of overheating the wheel bearing.
Old Mar 13, 2013 | 08:20 AM
Capt_bj's Avatar
Capt_bj
Mead Gardens
If you mean the show in Winter Park (Orlando) at Mead Gardens - yes
Rolling windows Mini
2nd in class 2010
1st in class 2011, 2012
this is a very attended well show in a particularly nice location. I'm pre-registered and will be there weather permitting. (I got caught in very heavy rain on the way home last year and it was NOT fun in a 79!)
http://allbritishcarclub.com/
btw B' are you on SunshineMinis.org?
Old Mar 13, 2013 | 08:27 AM
Capt_bj's Avatar
Capt_bj
I find that the 'hole' for the socket is not very deep so the secret is keeping the socket well seated.
My method:
1. Apply PB-Blaster liberally and give it 10 to 20 to soak in.
2. With a length of re-bar and two lug bolts wedge the hub so it can not rotate. ( visualize % )
3. With the T-50 on an 18 inch breaker bar I use one hand to press the socket firmly against the bolt while applying slow even pressure. If it does not come off with a good two UGH pull, I resoak and wait 10 more minutes
has not failed to get it loose by the second try and I've done GEN1 brakes for a dozen different cars.
As mentioned: When you put them back - anti-seize and you don't need 'em UGHd down. Just firm is enough. Saves your back next time.
Old Mar 13, 2013 | 02:41 PM
Braminator's Avatar
Braminator
Do I still get the ride? I have never been in an original and would love a ride. I also look forward to meeting other members.
Old Mar 13, 2013 | 03:14 PM
Capt_bj's Avatar
Capt_bj
Never been in an 'original'
OMG ......
We'll see what we can work out for sure . . .
I'll plan to stay a lil later than usual and maybe give you some time around town b4 I head home wx permit'
don't know of any exciting roads around the site tho
Old Mar 13, 2013 | 04:42 PM
Braminator's Avatar
Braminator
Toolman
Jan 20, 2016 06:50 AM
aldito2
Nov 25, 2015 09:33 PM
thebordella
Aug 31, 2015 01:37 PM
Powershift
Aug 16, 2015 05:14 PM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
