Is this normal?
Old Mar 12, 2013 | 09:40 AM
IzzyG's Avatar
IzzyG
Is this normal?
After installing my methanol kit, I noticed that my initial start up idle is jumpy(and so is the boost reading). I don't know if it has anything to do with the methanol kit since I guess I've not paid close attention prior to this.
Basically during a cold start, the boost gauge will do it's usual sweep and read 10 psi vacuum(so -10), although it usually stays in the -20(or 20 psi vacuum). In addition, the revs seem to go between 700-800. This goes on for 25-30 seconds and then the system settles down. Almost seems that someone's lightly throttling, even though it's just idling. I don't believe it's the cold start issue as there's no abnormal noises and otherwise the MINI runs normally.
Colt45Magnus
Aug 27, 2024 05:03 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
Shomare
39
Oct 19, 2015 03:33 PM
navybsn
Oct 4, 2015 03:27 PM
Miniwaukee
Sep 29, 2015 09:22 AM
