Suspension M7 Under Strut System question
Old Mar 12, 2013 | 01:28 AM
JCWKART's Avatar
JCWKART
Has anyone installed a M7 Under Strut System on there car? worth the money or didn't make a big enough difference?
Old Mar 12, 2013 | 02:02 AM
slinger688's Avatar
slinger688
I had it installed on my car for the last 4 years. Yes, it does stiffen up the chasis quite a bit.
Why do you think you want it?
Old Mar 12, 2013 | 03:54 AM
Melangell's Avatar
Melangell
You may want to consider the TSW X-brace.
Old Mar 12, 2013 | 03:56 AM
netma1000's Avatar
netma1000
I agree with slinger688.
Mine was installed several years ago in time for a DE at Road Atlanta. I could feel the difference in the turns although it was part of my larger scheme to stiffen the front with a M7 strut bar, and a larger rear sway bar. I've been very happy with the results.
Old Mar 12, 2013 | 04:35 AM
mattkosem's Avatar
mattkosem
Originally Posted by melangell
you may want to consider the tsw x-brace.
+1
Old Mar 12, 2013 | 05:58 AM
solskjaer1999's Avatar
solskjaer1999
Does anyone know if either under-body strut set up is compatible with the GP rear diffuser tunnels? It looks like they would be but I would hate for somebody to spend money on either or and find this out later.
Old Mar 13, 2013 | 11:53 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Don't bother with the M7 USS, had nothing but bad luck with it and noises.
The TSW X brace does the job right. As for fitting with the untrays, I've had people cut holes to the subframe bolts and install them. Otherwise the trays cover up the bolt holes.
Old Mar 13, 2013 | 12:49 PM
JCWKART's Avatar
JCWKART
I have the same set-up minus the under brace
Old Mar 13, 2013 | 12:51 PM
JCWKART's Avatar
JCWKART
is the x brace more streetable?
Old Mar 13, 2013 | 03:25 PM
GEMSTER's Avatar
GEMSTER
If I remember from Physics class, the X design is far stronger than a conventional rectangular shape.
So technically, the TSW X-brace should be more effective than the M7.
Old Mar 13, 2013 | 06:27 PM
WayMotorWorks
Vendor
Everyone has a street car, just some think they are race car drivers. I don't know of any brace system besides a roll cage that would make your car less streetable.
theateist
Jul 2, 2017 02:21 PM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
jeffbeckhudd
Aug 29, 2015 09:11 PM
nomar116
Aug 10, 2015 11:24 PM
