R56 Shutter at idle
Shutter at idle
Hey guys wonder if you had any ideas about this. The car is a 2008 r56s It had a bit of a shutter at idle ( almost as if it was going to stall). I used some seafoam and the problem stop. Changed the oil and it is back. I was thinking I will clean the maf. But I just dont know what else to look into before taking it in.
I had a similar problem with my 2008. It was determined as the "Vanos" system which is BMW's term for "timing". Yesterday, I had the solenoid at the outlet replaced and a flush by the dealer and the car is fine. The dealers flush is similar to a Sea Foam, but, it is with BMW fluid which according to the dealer won't void any warranty. Mini dealers also sell a flush fluid for $10.00. It is recommended as it contains recognized ingredients.
My car was doing the exact same thing, 2007 MCS with 68000 miles. Just had the walnut blast done 2 weeks ago and the problem is gone. The engine runs a lot smoother. Only paid $220 at a local BMW/Mini mechanic in So Cal.
Thanks for the replies guys! Will shop around for walnut blast. What mileage do y'all recommend changing the spark plugs? I got the car with 40k on it. Not sure if they have been done or not.
I think plugs are 50k and JCW is every 30k. Go with NKGs one step colder. If you got the money, replace the coil packs too.
Miniwaukee
Sep 29, 2015 09:22 AM
