Which is lighter weight, ES100's or Spec2's?
Old Apr 15, 2004 | 09:57 AM
kenchan's Avatar
kenchan
I am planning to wrap 215/40/17's on a set of S-lites that I am
hoping to be able to obtain in the next couple of days. I have
two sources right now.
Anyway, I know the s-lites are even heavier than my R90's but
like the design and would like to wrap some summer non-runflats
on them for fun. :smile:
Anyone know the weight of the ES100 or Spec2's in the 215/40/17
size? I might go Falkens, not sure yet.
no big hurry, but if you know, please let me know.
Thanks. :smile:
Old Apr 15, 2004 | 10:02 AM
MartyR's Avatar
MartyR
Ken,
There is something very, very wrong with being concerned over tire weight when you'll be running S-lites! hehehe
On a less sarcastic note, you might be able to find the info on the tirerack website checking under "Specs" for each tire. Hope this helps...
Marty
Old Apr 15, 2004 | 10:05 AM
kenchan's Avatar
kenchan
marty- hahaha, yah, I know...but there's not much other wheels that I like
out there for the look I am going for. Its either too ricy, or super expensive, or
wrong offset.
thanks for the info at tirerack. will check it out! :smile:
Old Apr 15, 2004 | 10:24 AM
MartyR's Avatar
MartyR
Ken,
Actually there's no weight info there, but try contacting Alex at the TireRack. He's always been very helpful to us MINI folks!
Marty
Old Apr 15, 2004 | 10:42 AM
meanboy's Avatar
meanboy
I don't know if edgeracing stocks the spec 2 but they list the ES100. Toyo tires are pretty light. I think the T1-S is just under 20lbs for 215/45/17.
found that es100 weighs 23.1Lbs and the Toyos are 20.1 lbs. (215/45/17)
Old Apr 15, 2004 | 11:04 AM
kenchan's Avatar
kenchan
meanboy- you're right, the T1's are probably the lightest, BUT hardest to
get a hold of around my area unless special ordered.
marty- yah, I was looking all over Tirerack, no weight info. hummm...
Old Apr 15, 2004 | 11:11 AM
meanboy's Avatar
meanboy
As obie would say...Luke, use the Internet!
Old Apr 15, 2004 | 11:14 AM
kenchan's Avatar
kenchan
yah, I kinda like to get tires locally unless ordered as a set from the Tirerack. :smile:
Old Apr 15, 2004 | 11:21 AM
meanboy's Avatar
meanboy
That's cool. I've never ordered from the tirerack but I will if they have what I need.
So they should stock Toyos..and soon!
Old Apr 15, 2004 | 11:37 AM
MINIAC's Avatar
MINIAC
The 215/40-17 Yokohama AVS ES100 weighs 21.8 lb:
Source: http://www.yokohamatire.com/pdf/avses100.pdf
I couldn't find any weight for the Parada Spec-2.
Old Apr 15, 2004 | 12:39 PM
Alex@tirerack's Avatar
Alex@tirerack
22.0 lbs
Alex
Old Apr 15, 2004 | 12:43 PM
dandp's Avatar
dandp
Guys - it's right at the top of this forum!
Wheel & Tire weights
Old Apr 15, 2004 | 01:55 PM
kenchan's Avatar
kenchan
Thanks!
Old Apr 22, 2004 | 03:39 PM
captainmini's Avatar
captainmini
i was told by someone at the tire rack that they would not even sell me 215/40 17 for the cooper s. is this a viable tire option for a 17 x7 rim
cheers,jon
Old Apr 23, 2004 | 07:24 AM
Alex@tirerack
>>cheers,jon
215/40 meets gross axel weight requirments, but I would not advise it, as you give up reserve of about 80 lbs a corner - Wich is no biggie, if you dont drive the car!
Alex
pglgp1292
Aug 9, 2017 12:45 PM
IrishMCS
Sep 15, 2015 05:43 AM
shahriar35
Sep 14, 2015 11:53 PM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
