R55 Things you might not know...
Old Mar 2, 2013 | 12:35 PM
Brad0428's Avatar
Brad0428
So I used to have a 1st gen Mini Cooper S and I was always on the forums and they have a thread called "things you didn't know about your mini". The thread had all kinda of very interesting facts about the 1st gen mini's. Now that I have a 2010 clubman I would like to know all the little like hidden facts about the 2nd gens. For example the other day I found out that the interior trim piece above the glove box also opens up as like a mini glove box.
Old Mar 2, 2013 | 02:05 PM
allgrainer's Avatar
allgrainer
I learned on this forum somewhere that if you hold the unlock button down on the key fob the windows will roll down. I tried it and it works on my 08S
Old Mar 2, 2013 | 02:26 PM
bkosh84's Avatar
bkosh84
If you have a sunroof, holding the unlock will also open that up too.. As long as it's aligned right and doesn't auto-close back down like mine does when it's hot out, lol.
Old Mar 2, 2013 | 06:18 PM
MightyNuts's Avatar
MightyNuts
when reversing with the rear wipers on, the wipers speed up. Also, there is only one reverse light.
Old Mar 3, 2013 | 07:56 PM
nakman's Avatar
nakman
I made my windows have the auto-up feature today, by accident. Was sitting in the car showing the wife how if you hold the remote unlock down that both windows will lower. Then somehow I have auto up and down, on both sides.
I found this thread tonight that likely explains better the mod I stumbled across https://www.northamericanmotoring.co...r-windows.html
Old Mar 3, 2013 | 08:30 PM
kcle730's Avatar
kcle730
auto-up by holding the unlcok again? or the lock button?
Old Mar 4, 2013 | 09:04 AM
nakman's Avatar
nakman
I believe it was the button on the remote that did it... though at first I tried holding the unlock switch on the dash but that didn't seem to do anything. It's possible the two are related though
Old Mar 4, 2013 | 09:06 AM
nakman's Avatar
nakman
Oh, and while digging around in the glovebox I found the little heat register valve. I presume this is to heat or cool the contents of the glovebox? Kinda cute... doubtful I'll rely on that for much though.
Old Mar 5, 2013 | 11:41 AM
Brad0428's Avatar
Brad0428
The r53's had that too, if I'm not mistaking it only blows cold air regardless if the heat is on or not. It works as a decent cooler for long trips.
Old Mar 5, 2013 | 11:43 AM
Brad0428's Avatar
Brad0428
The r53's had it too and if I'm not mistaking it always blows cold air regardless if heat is on. It works as a pretty decent cooler for long trips.
patsum
26
May 29, 2021 06:29 PM
riff42
Sep 22, 2015 03:07 PM
cdemarco4
Sep 10, 2015 10:14 AM
Panik
Sep 9, 2015 08:36 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
