R60 DMTL pump location, Code 1447
Old Feb 27, 2013 | 11:34 AM
RPatton's Avatar
RPatton
My quick research on code 1447 leads me to believe that the DMTL pump needs to be replaced.
Has anyone done this repair?
Location of the pump?
Thanks in advance, Robert Patton
Oops, Should have posted in "problems and fixes" Anyhow, all help is appreciated.
Old Feb 27, 2013 | 11:42 AM
Braminator's Avatar
Braminator
Sounds like a breather/ventilation issue, check your lines. Have you tried resetting the light to see if the same codes reappear? Since your MINI is so new you should just take it back to the dealer.
Old Feb 27, 2013 | 12:44 PM
RPatton's Avatar
RPatton
Previously a reset would take and I could drive around for a day or two. Now the fault will not clear which tells me the pump don't pump.
No dealer help on this car. Long story, short version: it is a salvage title.
Ideas?
RP
Old Feb 27, 2013 | 12:51 PM
Braminator's Avatar
Braminator
Like I said check the connections. If your gas cap seal is faulty or you have any fuel system pressure leak, this pump runs to maintain pressure in the system. Normally it is not supposed to run. When it runs it sets of the Check Engine light.
Old Feb 27, 2013 | 12:54 PM
Shoe Coupe's Avatar
Shoe Coupe
shouldnt your car be under warranty
Old Feb 27, 2013 | 12:55 PM
Braminator's Avatar
Braminator
He explained why.
Old Feb 27, 2013 | 04:38 PM
Bakerbrdz's Avatar
Bakerbrdz
Sell it if you can get the cel to go away
Old Feb 27, 2013 | 08:32 PM
RPatton's Avatar
RPatton
Bram, thank you for the diagram. I'll poke around by the fuel tank and see if I can find it .
Best regards, Robert Patton
Old Feb 27, 2013 | 09:08 PM
Braminator's Avatar
Braminator
Keep us posted. Good luck
Old May 31, 2018 | 07:52 PM
Eblessington's Avatar
Eblessington
Code 1447
Hi new to this but could use some help. My wife's 2011 r60 has a check engine light with loss of power under higher rpm loads. Code is 1447. I changed the fuel cap and dmtl pump with no improvements. Not sure where to go next and not ready to go to the dealer.
Old Mar 23, 2021 | 05:06 PM
Paul CC's Avatar
Paul CC
Did you find a solution for the 2011 R60? My 2012 has this code.
Old May 9, 2021 | 01:18 PM
contrail's Avatar
contrail
I made a post on this 6 months ago, it was in this forum. I'll see what--https://www.northamericanmotoring.com/forums/r60-countryman-talk-2010-2015/352818-dmtl-pump-notes-emission-diagnostic.html?highlight=dmtl+pump
Old Jul 22, 2021 | 10:44 AM
Paul CC's Avatar
Paul CC
Mine turned out to be the DMTL pump had failed. Easy fix on the 2012 R60 (it is located driver side, just in front of the rear wheel, under a plastic "skid plate."
Old Dec 17, 2022 | 10:05 AM
northamerican's Avatar
northamerican
Alabama
Where is the DMTL pump located? I don't see it by the charcoal cannister.
I do see a tube going up to the top of the tank.. assume that's the vent line.
is it under the other cover on the other side of the car?
Old Dec 17, 2022 | 01:19 PM
Paul CC's Avatar
Paul CC
On my 2012 R60 justa, it is about 6” in front of the rear tire, left side (drivers side) and is under a plastic skid plate. Not hard to change. Bosch part on Amazon works great. Until you top off the gas next time you are at the pump and the excess fuel flows down and ruins it. Then yo7 get to do it all over again. Ask me how I know.
Old Feb 28, 2023 | 05:19 PM
mylioes's Avatar
mylioes
Hi Paul, which part did you replace to resolve the fuel leaking into the new LDP problem?
Thanks!
Frank
Old Feb 28, 2023 | 07:14 PM
Paul CC's Avatar
Paul CC
Gas in Charcoal Filter
Thanks!
Frank
Frank, I’ve replaced the DMTL twice now, using the Bosch unit from Amazon. I’ve taken to not topping off even a bit when filling the tank. Not a drop. Seems to have resolved the issue.
Huneault
May 17, 2017 05:16 AM
BoostAddict
May 5, 2011 03:41 AM
