R56 Help: Need fix for loose Fog Light triggering bulb out warning?
Old Feb 26, 2013 | 05:08 PM
brinesi's Avatar
brinesi
Hi everyone,
My wife and I have a 2008 mini cooper hard top and are unfortunately selling it (need room for our growing family). We are getting a bulb out warning and I tracked it down to the passenger side fog lamp in the bumper. If I tap the fog light housing, the bulb pops on and the indicator goes off the next time I start the car. But then after a day, it comes loose again and the same thing happens. I've already removed the light from the housing through the bumper hole in the wheel arch and tried to tape the wires bent at the light joint thinking maybe it was a trip there but I still have the same issue. Has anyone had experience fixing this annoying issue? Thanks!
Old Feb 26, 2013 | 06:36 PM
Braminator's Avatar
Braminator
Not to be funny, change the bulb.
Old Feb 26, 2013 | 06:54 PM
Rgoodwin's Avatar
Rgoodwin
Could also have corrosion you might pull it and clean it up.
Old Feb 26, 2013 | 07:14 PM
calforhelp's Avatar
calforhelp
I believe a packet of this goo will help you out. I had one of my LED parking bulbs coming loose out of, put a little of this on the wedgebase and it no longer moves about.
http://www.autozone.com/autozone/acc...er=258987_0_0_
Old Feb 27, 2013 | 10:40 AM
brinesi's Avatar
brinesi
Ah... see I for whatever reason bypassed the thought of changing the bulb as soon as I saw that the bulb wasn't actually burned out, didn't think about corrosion on the contacts
Will try this, thanks guys!
Old Feb 27, 2013 | 11:47 AM
therealratfink's Avatar
therealratfink
Had the same issue and used anti-seize because I had it. Works the same way and no more problem. Is yours the drivers side as well? Just curious.
Old Feb 27, 2013 | 02:49 PM
brinesi's Avatar
brinesi
I just changed the bulb, it looked like the bulb was like half burned out as it was half black but still was lighting up, never seen a bulb appear half burned out like that.
Actually it was the passenger side!
Old Feb 27, 2013 | 03:12 PM
Capt_bj's Avatar
Capt_bj
Very rare but I've seen the filament of a bulb burn & break but because of the orientation of the bulb and the way the end hangs make occasional contact . . . .
Always start with the easy stuff!!!!!
Old Feb 27, 2013 | 03:17 PM
xsmini's Avatar
xsmini
I had a tail light that was dong that awhile back. My son was driving the MINI and got pulled over for the light being out. When he got home I went out and checked it and t worked just fine. Took the bulb out an the filament wire was broken. Apparently depending on where the wire was when the lights were turned on determined if the light came on or not.
Nik
Old Feb 27, 2013 | 03:43 PM
Braminator's Avatar
Braminator
So changing the bulb solved your problem?
Old Feb 27, 2013 | 04:08 PM
Braminator's Avatar
Braminator
Dec 23, 2015 10:36 AM
Zettinger
Aug 25, 2015 04:04 PM
AZN Optics
Aug 16, 2015 11:52 PM
