Suspension R58 vs R56 Coilovers (Fitment Issues?)
Old Feb 25, 2013 | 11:38 AM
zcast's Avatar
zcast
Just curious, because I haven't seen it spelled out anywhere on the forums that I could find. I want to know if in general, all R56 coilovers would be a direct fit for the R58? From what I have read, they shouldn't be any issue other than maybe a manufacturer changes spring rates, but since the weight is nearly identical, there shouldn't really be a need. On different sites I see different part #'s for R56 vs. R58 but the specs are identical.
Is it safe to say they will fit? If someone was to build a custom set of coilovers following the R56 specs, they would work on the R58?
-Z
Old Feb 25, 2013 | 01:29 PM
GEMSTER's Avatar
GEMSTER
Unless you are going for "because racecar" and you want that extra hundredths of a second, then you should probably get custom R58 specific coilovers. Other than that, an R56 setup on a R58 should perform just fine.
Old Aug 19, 2015 | 09:30 AM
suxo's Avatar
suxo
Is any new info about fitment? Will R56 suspension fit on R58 without any problem?
Old Aug 19, 2015 | 09:35 AM
GEMSTER's Avatar
GEMSTER
It will fit. R58/R59s are exactly the same as R56s from the belt-Line down.
Hippiehobbit267
Dec 3, 2019 04:22 PM
Aug 19, 2015 12:51 PM
Aug 19, 2015 12:34 PM
ASRman
Aug 13, 2015 09:33 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
