R50/53 p2096 code
Old Feb 23, 2013 | 06:01 PM
trashmanbob's Avatar
trashmanbob
p2096 code
NEED HELP!
I drove my 2005 MCS from Sac, Ca. to SF bay for vacation about 300 miles the longest distance I have gone in it. Guess what, the service engine soon light came on. Feaked out, then I took it to the mini dealer $180.00 later they couldn't tell me what was wrong and said I need to give them more $$$$$$$ for testing. Came home and check NAM's web site forum. All that I could find was treads from 2007. Anybody know more about this, it looks like it is a problem with 2005 MCS cars.
Thanks Bob
Old Feb 23, 2013 | 06:09 PM
ViperNL's Avatar
ViperNL
Quick google search came up with: https://www.northamericanmotoring.co...750-post4.html
Old Feb 23, 2013 | 06:32 PM
Braminator's Avatar
Braminator
Generally this seems to be some sort of leak in the intake track. In many cases it has been a leaky intercooler boot, leaky bypass valve, (air leaking into the valve not past it), cracked intake tube between the trottle and the superchrager.
The code could be due to an O2 sensor issue also.
Old Feb 23, 2013 | 06:33 PM
Braminator's Avatar
Braminator
Also do you have a header on it? It can be the flange not sealing.
Old Feb 23, 2013 | 06:46 PM
trashmanbob
code
No I don't have after market ex, but I have a JCW air cleaner that I installed about 9 mouths ago and it has a vac hose that had to be attached to the intake. Had on problem driving local, 1st long trip.
Old Feb 23, 2013 | 07:11 PM
Braminator's Avatar
Braminator
The air filter did not cause it unless the intake hose has a crack or hole in it.
Old Feb 23, 2013 | 07:24 PM
trashmanbob
ya, that is what I am going to check.
Old Feb 26, 2013 | 11:48 AM
Darren89's Avatar
Darren89
When my Light came on it was the O2 Sensor at about 80K or so. Also, if you come across some bad gas it makes the compputer read wrong and the light will come on. That just recently happened to me. So now I strictly use Shell or Chevron Premium only. ( After adding this to my tank the engine light turned off immediately).
Old Feb 26, 2013 | 11:50 AM
Darren89's Avatar
Darren89
Follow Up to above
My check engine came on twice. 1st the O2 Sensor the 2nd O2 sensor.. I bought mine from a site for really cheap. I'll try looking for it just in case it is your O2 sensor. And the 2nd time was because of bad gas :/.
Old Aug 22, 2013 | 09:35 PM
Some Guy's Avatar
Some Guy
I had my car in 3 times under warranty for this. Leaks in 3 different locations... Eventually ran out of time on the warranty and became stuck with it.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
