Navigation & Audio 3-Way? or 2-way tapped.......
Old Feb 22, 2013 | 08:20 PM
cumang0's Avatar
cumang0
I have the standard Mini Boost audio system (the one which pathetically does not have tweeters) and have installed HK Pillar Tweeters.
Does this convert the front channels into a 3-way setup?
Will I have issues with running an aftermarket HU with 4-channels? (read and understood other issues such as keeping original radio circuit board to preserve on-board computer)
Old Feb 26, 2013 | 04:51 PM
rAte's Avatar
rAte
I am in for the info on the pillar tweeters. Were they already powered by the boost HU?
I have a pair of boston 1" tweeters in my garage, but no crossover for them any more...
Thanks!
Old Feb 26, 2013 | 06:23 PM
cumang0's Avatar
cumang0
Thanks!
the tweeters work so they must be powered by the HU. all speakers work...
Old Feb 26, 2013 | 07:16 PM
sbeezy's Avatar
sbeezy
No you basically have a 2way setup with a tweet added to the mix.
a 3 way setup would be low,mid,high and each frequency range would have its own passive or active x-over attached to the appropriate driver.
they could also be tri-amped when going active.
Old Feb 27, 2013 | 10:23 AM
cumang0's Avatar
cumang0
would adding a 3-way crossover help the situation if i changed the HU? I have an appradio unit coming in but i need to sort out this dilemma in case there's sound quality compromise due to this sub-3 speaker setup. if not then i guess i'll have to retire the mid-range and run the 6.5's and the tweeters....
thanks for the input. much appreciated.
Old Feb 27, 2013 | 10:37 AM
sbeezy's Avatar
sbeezy
I would check the specs on the appradio to see what xovers it has to be able to better understand what path it is you would need to take to reach the goals you are after. I would also recommend you do some sound treatments to your car while you are ripping the car apart.
Old Feb 27, 2013 | 02:16 PM
cumang0's Avatar
cumang0
will do, thanks again. probably will pass on the sound treatment; if i do it i won't simply dynamat everything as many do. i would go all out and use many different materials upon each other to create the best possible outcome, but due to the fact that the car relies somewhat substantially on weight for performance (especially when the mini have is a 1.4l) as well as the cost entitled with such a feat.......:(.
i think i'm just going to ditch the whole 3-way thing and retire the mid-range. i don't know how i am going to wire up the 2-way components i'm looking to install though..
Old Feb 27, 2013 | 02:20 PM
sbeezy's Avatar
sbeezy
Are you using head unit power or outboard amps to power said component set?
Old Feb 27, 2013 | 03:14 PM
cumang0's Avatar
cumang0
head unit power. mosfet 50x4. 20x4 rms.
gar56
Nov 15, 2016 06:41 AM
nashvillemini
Sep 30, 2015 10:26 PM
Robin Casady
16
Apr 19, 2009 07:15 AM
Eds not-so-red MINI
Jan 29, 2008 05:08 PM
kapps
Sep 23, 2007 10:37 AM
