Bubbles
Old Feb 15, 2013 | 06:35 PM
CooperS84's Avatar
CooperS84
Bubbles
I was recently in a small car accident where someone cut me off causing me to rear end them, I'm not sure if the bubbles which are oddly enough in the same exact position on both of my front tires are a result of this but I was wondering if this could be a possibility?
Also, are bubbles a sign that my wheels are bent?
Old Feb 15, 2013 | 06:50 PM
Braminator's Avatar
Braminator
Post a pic. But this could be the seam of the tire also.
Old Feb 15, 2013 | 06:57 PM
CooperS84's Avatar
CooperS84
I'll post one tomorrow.
Old Feb 18, 2013 | 07:49 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Likely your tires have a ruptured or weakened sidewall causing a bleb in the tire side.
see
http://www.pistonheads.com/gassing/topic.asp?t=1074548
If your tires look like this, if so then replace both tires.
Old Feb 18, 2013 | 08:00 PM
ZippyNH's Avatar
ZippyNH
If the tires have a deformed sidewall, trash them. You will not know if the rims are bent till you mount new tires and balance them....a good tire shop most likely CAN look at them when you unmount the old tires,but by then, you are gonna mount new tires and try them out anyway....
I'm guessing the tires were subjected to an impact, bump or pinch....and that dammaged the sidewall leading to failure. And i say failure, cause the tire HAS FAILED, it is just holding air still....even a short low speed drive..meaning a few blocks or a mile or two to the tire shop could be dangerous....a front tire blowout at the wrong moment is bad...then maybe a second when trying to correct for the first.....
Old Feb 19, 2013 | 01:26 PM
martinb's Avatar
martinb
If it looks anything like the one in that link, it's damaged. Don't drive on it unless you can't help it. And if you do drive on it, do NOT drive at high speeds or on the freeway or highway.
Old Feb 19, 2013 | 02:46 PM
Capt_bj's Avatar
Capt_bj
YEP
if the bubbles are in the sidewall the tires are dangerous to drive on . . . actually bubbles anyplace mean the same thing but I doubt you'd see them on the tread.
Reminds me of a time I was scuba diving (shore dive) and noticed a bubble starting to form on the high pressure hose to my gauges .... meaning air was no longer being held inside all the many layers but was escaping to the last layer causing a balloon .... and when that balloon pops, there goes my air supply! I surfaced as fast as I safely could and went straight to the dive shop for a new hose..... If that had blown earlier in the day when I was at 100 feet "off the wall" in Cayman. OMG!
Old Feb 19, 2013 | 04:26 PM
Rgoodwin's Avatar
Rgoodwin
Been "off the wall" in their submarine ! Awesome trip! Snorkeled off some steep rocks down from a stand-alone bar somewhere I think on east side. Wondered why we were the only ones there, then we saw the sharks-prob nurse sharks or something harmless but I'm from the Ozarks so we were outathere!
fridayxiii
Mar 24, 2022 04:41 PM
ronn
23
Sep 5, 2017 10:36 AM
silence2-38554
Sep 28, 2015 12:19 PM
RHcoopers
Sep 20, 2015 10:01 AM
reverse01134
Sep 1, 2015 08:50 AM
