Drivetrain Scorpion headers.
Old Feb 12, 2013 | 06:28 PM
tweiss8's Avatar
tweiss8
Scorpion headers.
Has anyone heard of them? Searches only come back with the cat back system. Same with YouTube. From what I understand, they have a cat in them. I'm just looking for basic info.
Price.
If the cat is decent.
If it throws codes.
Fit and finish.
Any insight would be appreciated.
Old Feb 22, 2013 | 02:33 PM
tweiss8's Avatar
tweiss8
No one?
Old Feb 22, 2013 | 02:42 PM
JCWSLAYER's Avatar
JCWSLAYER
Never heard of them myself.
Old Feb 22, 2013 | 05:43 PM
tweiss8's Avatar
tweiss8
Bav auto has them on clearance, just having a hard time finding info, searches have come back with the cat back system, just no header. Even the manufacturer site shows cat back and no exhaust. Interesting.
Old Apr 5, 2013 | 06:57 AM
BluR53's Avatar
BluR53
I have the cat back exhaust system as well as the sport manifold on the way (aka header) My header will be here on monday April 8th and I expect my exhaust a few days later. I am certain it will throw codes from my O2 sensors so I am planning a dyno tune for once I have everything installed. I am putting on an Alta CAI, Alta 15% pulley and new belt, Scorpion exhaust, and Scorpion Sport Manifold with High Flow Cat. I am also planning to do an oil change on my supercharger while I'm at it.
Old Apr 5, 2013 | 07:34 AM
BlwnAway's Avatar
BlwnAway
Since you're not doing this for a while, it may be beneficial to get a couple of O2 sensor spacers to have with you, "may" help out with code issues.
Old Apr 5, 2013 | 07:37 AM
BluR53's Avatar
BluR53
Thanks for the advice! Any idea where I might be able to pick up spacers? also...what do they do? I am kind of making this up as I go at this point. Lol
Old Apr 5, 2013 | 07:52 AM
BlwnAway's Avatar
BlwnAway
Just do a search you should be able to get then easily, summit, jegs, any place like that.
Basicly the concept of why spacers some time work is because in a 2 sensor system, (pre & post cat) the sensors not only read gasses & such, they are designed to read a variation in levels between the 2, this tells the ECU that the CAT is working properly, by spacing one or the other back/out slightly it causes the sensor to read slightly different.
Not a guarenteed fix, but they are not expensive & it may just be beneficial to have on hand.
Old Apr 5, 2013 | 08:35 AM
mgrant's Avatar
mgrant
spaces basically move the O2 sensor away from the incoming gases. By moving the O2 sensor away from the gases it reads concentrations lower than what they actually are wish could trick the system into thinking everything is ok
Old Apr 5, 2013 | 09:51 AM
BluR53's Avatar
BluR53
Thanks so much BlwnAway and mgrant...I went down to the auto parts store and explained to the shop guru what I was doing and half way through my explanation he stopped me and walked me down to the spark plug non-foulers. He said he did the same thing to a civic he had. You can use a non-fouler to do the same job as an O2 spacer and it only costs you a few bucks (I think mine set me back $6). He said it'll stop the code from coming up but I do plan on having my car tuned over the summer so I'm just going to use it as a temporary fix for the rear O2 sensor. Thanks for all the pointers guys! I can't wait to start installing now
Old Apr 5, 2013 | 12:28 PM
jpinkerton's Avatar
jpinkerton
This is exactly what I was going to mention. I am not sure of the exact 02 orientation on the Mini, but on my EP3 Civic Si there was a primary wideband and secondary narrowband.
By putting a sparkplug fouler in between the secondary and the bung it allowed the sensor to be removed slightly from the exhaust stream, which would trick the car in to thinking that there was a cat installed and it was operating properly. It was an easy $5 option!
Old Apr 16, 2013 | 02:20 PM
BluR53's Avatar
BluR53
Wanted to keep you guys all posted on the Scorpion install. Everything went pretty smoothly. We just dropped the entire exhaust all at once seeing how the bolts that connected the down pipe from the header to the long pipe for the cat back were rusted on there. I will say that before you start this project that you should go and pick up new bolts and nuts for the down pipe as well as a new gasket. Scorpion or Bavarian Auto Sport doesn't provide you with any new hardware. Also you are probably going to want to pick up a new lower O2 sensor as mine was also rusted in place. The cat in the manifold is HUGE but it fits in the car perfectly. I was able to avoid throwing any codes from my ECU by using a spark plug non fouler on the lower O2 sensor. My car runs just fine and dandy without a tune. I plan on posting a tread soon about the whole install once I get an after install vid. I absolutely love the full scorpion exhaust. Its a nice mellow sound when you're just driving around but when you get on it she can sure scream! It doesn't sound ricey at all. Which is exactly what I was looking for.
Old Apr 16, 2013 | 03:18 PM
tweiss8's Avatar
tweiss8
Thanks for the update! Where did you pick your headers up?
Old Apr 16, 2013 | 04:32 PM
BluR53's Avatar
BluR53
http://www.bavauto.com
In the departments its under "Exhaust" then "Performance Exhaust Systems". The Scorpion header has no picture but its titled "Scorpion Sport Manifold With High Flow Catalytic Converter"
Bavarian Autosport ships really REALLY fast. I think it only took 4 days for me to get my header.
Old Apr 16, 2013 | 04:50 PM
Braminator's Avatar
Braminator
Old Apr 16, 2013 | 08:10 PM
miniblucabrio's Avatar
miniblucabrio
Glad to hear you like it! Thats what i like about this exhaust. Its quiet when just cruising but get into the throttle and people know your coming. I can't wait to get the header for mine!
Old Apr 16, 2013 | 08:39 PM
BluR53's Avatar
BluR53
You will love it just make sure you pick up some new nuts and bolts, exhaust gasket, and O2 sensor before you get started. Other than that it's pretty much a breeze. You might only need the O2 sensor as you have already have the catback exhaust on so you're bolts should be pretty rust free and you'd have recently put a new gasket on. The lower O2 sensor is probably rusted on to your downpipe so just save yourself the headache and by one before you get started. Also if you want to avoid throwing an engine code pick yourself up a spark plug non fouler that'll fit your O2 sensor. It works like a charm. My car doesn't have an engine light lit up and its running just fine. Not running rich at all.
Old Apr 17, 2013 | 05:18 PM
tweiss8's Avatar
tweiss8
Wish I would of grabbed it when it was $550! It's pricey now.
Old Apr 17, 2013 | 09:37 PM
BluR53's Avatar
BluR53
I thought it was cheaper a few months ago. Lol. I wish I'd have gotten it then but oh well. It is still definitely worth the price. I'm sure they had a sale on it because it was winter and there aren't very many people wanting to do installs on their cars in the middle of winter. At least its still 10% off.
Old Jan 19, 2017 | 03:51 PM
Linz Proctor's Avatar
Linz Proctor
I have this header and cat. It's throwing a p2096 code. Put the spark plug non fouler in. No difference still throws code! Anyone have any idea?
Old Jan 21, 2017 | 01:35 PM
X757XVeritas's Avatar
X757XVeritas
Have you used a code reader to clear the code? Or just threw the spacer on and hoping it will go away?
I'm not sure if it will clear itself. Also it's not a guaranteed fix anyways.
Old Jan 21, 2017 | 03:42 PM
Linz Proctor
P2096 is a hard to hard code. Only certain scanning tools will clear it. Will not go away by itself. Must find the leak in one of the gaskets and clear it with a Bavarian technic tool.
smportis
Feb 5, 2020 09:54 AM
WhinyR53
Sep 30, 2015 07:36 AM
mikeyb74
Jun 1, 2015 05:10 AM
ZippyNH
Nov 12, 2010 10:41 AM
fueledbymetal
18
Aug 24, 2006 02:55 AM
