R50/53 Trunk Power Outlet?
Trunk Power Outlet?
I bought an 02 MCS. In the trunk area is a hole on the left side and a wire connection. So I went to the Mini dealer today and they sold me an illuminated ring and 12v socket that is supposed to go there according to their diagram. However, the illuminated ring will not fit into the hole without some modifications, but the 12v socket does connect and works correctly. Can anybody tell me how this part is supposes to fit into the hole? I'm just looking to put the car back into the original condition. I have searched the net for info, but no luck.
Thanks!
Thanks!
I had a broken orange ring below the toggle switch bank, so I swapped in the one from the trunk... I had the same experience, it just does not fit. I ended up using a thin screwdriver to pry the hole a little wider so I could pop the assembly in at an angle. I'm sure this isn't the ideal solution, but it's in there now.
Thanks guys for your help!
I was able to fit the factory illuminated ring (after shaving a bit of the ears off) and socket into the factory hole and plug into the factory wiring harness connection. Even though I had snapped the two pieces together already it just popped right into the hole with no difficulty. Of course the illuminated ring is not lit and is not supposed to be. Also, the fuse for this (12 volt power outlet) factory harness connection is F31 located at the drivers foot rest. I hope this info helps someone else in the future.
Thanks again!
Thanks again!
Interior/Exterior Must see: Liberty Walk body kit for Mini Cooper R56
carid
Dec 28, 2025 04:11 AM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
