Drivetrain Cold start problem
Old Jan 29, 2013 | 11:25 PM
couper1's Avatar
couper1
Cold start problem
Hi
The weather is around 0 degree celcius.
mini is 10k kilometers.
I have to try 3-4 times to start the engine. It never start first time.
Do you have any advice?
Old Jan 30, 2013 | 03:02 AM
Mical's Avatar
Mical
Mine turns over a little slower when in the lower temps (0 and below, but always starts first time) so providing you're using proper grade fuel I'd have dealer look at it.
Old Jan 30, 2013 | 04:18 AM
Braminator's Avatar
Braminator
Reason 1 - Gasoline, like any other liquid, evaporates less when it is cold.
Reason 2 - Oil gets a lot thicker in cold weather. .
­Re­ason 3 - Batteries have problems in cold weather, too.
Old Jan 30, 2013 | 06:11 AM
chrunck's Avatar
chrunck
Could be a bad thermostat.
Old Jan 30, 2013 | 06:51 AM
bmwr606's Avatar
bmwr606
my 2012 cms all4 so far has started on the first try every time in the cold, coldest so far was -6F
it cranks a little slower, but fires right up and idles nicely
i think a trip to the shop is in order
scott
Old Jan 30, 2013 | 10:11 AM
couper1's Avatar
couper1
I'm using 95 octane gasoline.
I asked about thermostat, it is ok.
How much do you press the start button (seconds)?
Do you press throlle during pressing start button? (left foot brake, right foot throlle)
Old Jan 30, 2013 | 01:58 PM
y8s's Avatar
y8s
modern cars do not need throttle input during cranking.
in cold weather (15F/ -9C) I press the button briefly (<1 second) and the mini fires up instantly. cranking never takes more than 2 seconds (if that).
battery age can also play a big role in starting behavior. cold weather does affect battery cranking power.
Old Jan 30, 2013 | 03:38 PM
bmwr606's Avatar
bmwr606
press start and release immediately
i don't touch the throttle at all
scott
Old Jan 31, 2013 | 03:21 AM
couper1's Avatar
couper1
Battery is 2 years old and shows 14v on odb2, also there isn't any fault code.
I have to go to service...
Do you suggest 98 octane or 95?
Old Jan 31, 2013 | 05:54 PM
y8s's Avatar
y8s
your octane ratings are probably not the same as in the US (I assume you're not). IF they are are RON instead of R+M/2, then you probably want 98 RON which is roughly equivalent to a US 93 R+M/2. 95 RON would suffice but on a modern turbocharged motor, higher = better generally.
iggi
18
Feb 9, 2026 01:00 AM
Melvinyip
Apr 17, 2020 09:28 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
alistaircookie
Oct 8, 2015 10:52 AM
