R56 HK speaker issues
Old Jan 28, 2013 | 05:17 PM
quattro4's Avatar
quattro4
HK speaker issues
I've had my 2010 MCS for about two weeks now. Noticed crackling coming for the front driver side speaker. It only happens when it is at a certain volume.
I have h/k sound.
I thought it was the radio reception but I don't think so.
Does any know what it could be?
And is it covered by the warranty?
Thanks in advance.
Old Jan 28, 2013 | 05:20 PM
ocluck's Avatar
ocluck
should be cover by warranty if it can be reproduced.
Old Jan 29, 2013 | 04:02 AM
strobeyprobey's Avatar
strobeyprobey
Probably a rattle in the door. Google bink audio test cd. Burn and run through the tones to find the track with the offending frequency. Then tell your dealer that track. I had to do this a few times. The dealer fixed it each time under warranty. Having the test cd was the only way I could get them to hear the nasty rattles that sounded like blown speakers.
Old Feb 1, 2013 | 09:48 PM
nebulosity's Avatar
nebulosity
This happened on my '11 MCS. The dealer added some felt tape on the joints between the dash and A pillars. I still noticed occasional rattles and found they came from the doors. The side "map" pockets in the doors are separate pieces from the door plastic and this caused a crackling or rattle at certain frequencies. I solved it by pulling on the pocket and putting a couple small pieces of felt on the seem between the two parts. This may make more sense if you look at the door.
woodstudio
Mar 15, 2020 08:28 AM
khumpert
Nov 30, 2015 11:48 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
clintmeister
Aug 27, 2015 12:08 PM
OutMotoring
Aug 6, 2015 09:32 AM
