R55 Check Engine Light ?
Old Jan 26, 2013 | 09:40 PM
Johnny Danger's Avatar
Johnny Danger
I understand that a bulb error will cause a bulb symbol to appear on the tachometer. However, is it possible for it to cause a check engine symbol ? Or is it simply a coincidence that this occurred after installing some LED plate bulbs ? My vehicle is 2012 Clubman S that is a little more than a month old with 900 miles on it .
Old Jan 26, 2013 | 11:53 PM
minicooper1985's Avatar
minicooper1985
Probably coincidence. Ours had a bad knock sensor at about a year old. Defective parts can happen. If the dealer's not too much of a distance, get it checked since I can guarantee you're under warranty. Well, I'd really, really, really, really hope you are. Because you are.
If they are too far, see if a closer BMW dealer will do it or if any other shops can/will do Mini warranty work. I'm not sure if there are, but others should be able to clarify this a little, I'm sure.
Old Jan 28, 2013 | 01:49 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
Do MINI Clubs have a globe check system? My Australian spec one does not.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
