Suspension Sagging suspension
Old Jan 21, 2013 | 04:13 PM
Jgoins's Avatar
Jgoins
Sagging suspension
I have a 02 copper s with koni fsd's and H&R sport springs. The problem is while driving when I hit any type of bump in the road the driver side rear is rubbing and like its bottoming out. Any help on what the problem may be would greatly be appreciated. Running 205/45/17's. Thanks Jgoins
Old Jan 21, 2013 | 04:51 PM
Braminator's Avatar
Braminator
You probaly blew out the shock as they are not recommended for use with lowering springs.
Old Jan 21, 2013 | 04:52 PM
Braminator's Avatar
Braminator
Here is right from their website.
FSD Shocks
KONl`s latest technology accomplishes the task that has eluded most shock makers until now - great handling + excellent ride quality:
  • > Excellent ride quality on all road surfaces
    > Available for most newer cars - more coming
    > Pair with Eibach springs for 1"-1.5" lowering(Excludes Mini)
    > Gold metallic finish shocks
    > Less expensive than electronic systems
    > Lifetime Warranty
Old Jan 21, 2013 | 05:13 PM
Jgoins's Avatar
Jgoins
What shock would you recommend? Thanks
Old Jan 21, 2013 | 05:17 PM
Jgoins's Avatar
Jgoins
That is what shock with the current H&R springs
Old Jan 21, 2013 | 05:18 PM
Braminator's Avatar
Braminator
Koni yellow sports since you already have the lowering springs.
Old Jan 21, 2013 | 05:31 PM
Jgoins's Avatar
Jgoins
Should I replace all four or just both rear?
Old Jan 21, 2013 | 05:37 PM
Braminator's Avatar
Braminator
Since you will be changing models, I would highly suggest you change all four.
Old Jan 21, 2013 | 07:25 PM
ColinGreene's Avatar
ColinGreene
always change all 4 at once.
Its not too bad of a DIY job if you have done suspension either.
Old Jan 22, 2013 | 08:48 AM
rjtrout2000's Avatar
rjtrout2000
Originally Posted by braminator
koni yellow sports since you already have the lowering springs.
+1
Old Jan 22, 2013 | 03:38 PM
Jgoins's Avatar
Jgoins
Got the Koni yellows ordered today. Is this a easy swap. Never done suspension work before, or would I be better off taking it somewhere. Don't mind doing it myself if not to complicated. Any suggestions would help or any directions on how to swap them. Thanks
Old Jan 22, 2013 | 03:43 PM
Braminator's Avatar
Braminator
It is not complicated just time comsuming. You will need a spring compressor and some hand tools. Then you should be able to do it.
This will walk you through it.
http://www.pelicanparts.com/techarti...eplacement.htm
Old Jan 22, 2013 | 03:45 PM
stevenpollock's Avatar
stevenpollock
Did my first suspension job this weekend, pretty easy. The biggest thing is making sure the strut is in ALL THE WAY and the pinch bolt goes THROUGH the fin on the strut. I missed this and and it was a catastrophe, my car is now undrivable until next week when my new cv boot comes in. Stupid mistake, just don't make it!
Old Jan 23, 2013 | 12:30 AM
pgrizard's Avatar
pgrizard
Did you check the spring to be sure it didnt come unseated? Have you stood in the boot and bounced the car up and down to test and listen? If you are changing its a good time to replace front strut bearings (with new oem or plates) and possibly some bushings if you want to put some life back in that 02. The front lower control arm bushings have been said to need to be replaced every 50k mi and oh my what a difference new ones make. You might need some tools for the strut end nut, pretty hard to do without strut socket.
Old Feb 6, 2013 | 02:49 AM
RockymiN's Avatar
RockymiN
Always do try and modify all 4 at once. Its not too bad of a DIY job if you have done revocation either.
vulkandino
Oct 31, 2015 08:29 PM
GAT
Oct 4, 2015 07:27 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Emnotek
Sep 29, 2015 07:37 AM
