R55 2010 Clubman JCW on NW Springs w/15mm Spacers
Old Jan 16, 2013 | 11:54 AM
aabrahams's Avatar
aabrahams
Wanted to share this. Pic of my 2010 JCW Clubman with NM Eng Lowering Springs & 15mm H&R spacers on all four corners. No rubbing to report. Much improved ride quality & feel. Very pleased with these two mods.
Attached Thumbnails 2010 Clubman JCW on NW Springs w/15mm Spacers-photo.jpg
Old Jan 16, 2013 | 01:55 PM
R56BrgMcs's Avatar
R56BrgMcs
I like it. Do the spacers require longer studs?
Old Jan 16, 2013 | 03:06 PM
aabrahams's Avatar
aabrahams
Longer studs would be prudent. This combo with the stock JCW 17 works like it was designed to.
Old Jan 16, 2013 | 03:57 PM
Day177017's Avatar
Day177017
Any issues with camber? Or are you not worrying about uneven tire wear, if any?
Old Jan 16, 2013 | 04:11 PM
aabrahams's Avatar
aabrahams
Installed lower adjustable rear control arms. Runing 1.75- in the rear. The arms are needed.
Old Jan 16, 2013 | 04:12 PM
Day177017's Avatar
Day177017
Fronts have no issues? Drop looks good, btw
Old Jan 16, 2013 | 04:16 PM
aabrahams's Avatar
aabrahams
No issues in the front either. The car feels much better now. The 22mm bar (softest setting) improves turn in even at low speeds. Really could not be more pleased with this combo mod. Might do a NM front strut tower bar next for good measure. Then the suspension should be sorted as far as i want to go.
Old Jan 16, 2013 | 04:18 PM
aabrahams's Avatar
aabrahams
Thanks for the complements! Stoked with this car. Really want a full leather JCW steering wheel and shift **** next.
Old Jan 16, 2013 | 04:25 PM
RobMuntean's Avatar
RobMuntean
It looks awesome! Did you add the bump stop kit?
Old Jan 16, 2013 | 04:34 PM
aabrahams's Avatar
aabrahams
Yeah. It drives like a completely different car. Less wheel spin on corner exit & much less body roll. Thought about buying the bump stop kit but it was not needed. Just trimmed the OEM stops per instructions. Its really transformed the car and the cool thing is you could do this with a base clubmen with the same results. Not sure how it would play out on smaller rims but if im not getting any rub on 17s anything smaller should be fine. The spacers do a nice job pushing out the rims well into the arch and give the car a really aggressive look - and picked up 30mm additional track f/r. It was a gamble but we now know it works - phew
Old Jan 18, 2013 | 02:45 PM
RobMuntean's Avatar
RobMuntean
I don't have a clubman but I'm doing the same route after Chad from DT told me try the springs first. Now I was looking at the same thing as you on the spacers, just think I might go the 15mm or 20mm if its possible. I want it to ride and handle great!
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Longjas
Aug 24, 2015 06:06 AM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:37 PM
Aug 11, 2015 12:34 PM
