Horn went out?
Old Jan 15, 2013 | 02:34 PM
BernieCoop's Avatar
BernieCoop
Horn went out?
I was just wondering if any other members have had their horn go bad on them. From what I have learned, the MINI has two horns, one low pitch (passengers side) and one high (drivers side), I believe the low pitch one is out on my MCS and it sounds like the high pitch isn't doing much better. I thought this was weird because I have never heard of a horn going out. Just checking for experiences and maybe a how-to because I'll be replacing probably both real soon. I don't even know where the horns are located...
Old Jan 15, 2013 | 02:45 PM
Braminator's Avatar
Braminator
Check
1. Fuse
2. Check connections for corrosion to the horns
3. Horns themselves.
Old Jan 18, 2013 | 06:07 AM
Capt_bj's Avatar
Capt_bj
just got done doing some horn work on an 03-S
1. The horns are right next to the parking light/turn signals, one on either side of the bumper - you can see them thru the same access hole you get to the bulbs for the pl and ts. That's the good news. Bad news is the access is REALLY tight and try as I did for too long I just could not get the horn out thru that access. I was really really tempted to enlarge the hole a wee bit and then the horn could come out this way but owner didn't want that done. The 'book' way to get to the horns is to remove the bumper cover which is not that difficult {I have some DIY - part of the one kicking around for the Aero Grill replacement} .
2. If one of your horns is {kinda} working, then the fuse & relay must be OK. The electrical connector if still all OE is really tight and I doubt you're getting water intrusion - I tried to remove the horn from the top when I could not get my fingers in there to disconnect the wires - the single TORX holding the horn in place is easier to get to. I released this bolt which allowed me to flop the horn around and get easier access to the connector. You could verify the electrics are OK with a volt meter once you get the connector off.
3. I have talked to folks who's OE horns 'broke' ... it happens. The OE horns are nothing particularly fancy EXCEPT for the fancy OE wire connector. These Hella horns
http://www.griotsgarage.com/product/...ortby=ourPicks
are an almost perfect match except for standard blade connectors. The OE horns are already on a relay so these horns could be a quick and easy swap - you just need to cut the OE connector off the end of the harness and crimp on generic connectors. (brown wires are ground - other wire is the power).
4. My 'customer's horns were still working, he wanted MORE and better sound. We added a set of the Hella's just referenced. This additional set of horns went in the void under the cowl on the pass side right against the firewall. We added a sep' relay so as to not overload the existing horn circuit since we were doubling the load - and just tapped one existing horn power wire as the new relay trigger. He now gets 4 horns when he pushes the button - lots of noise! This same location is where a lot of folks put a small set of air horns or even something like this
Old Jan 19, 2013 | 07:57 PM
BernieCoop's Avatar
BernieCoop
Thanks guys for the replies. I'll definitely be looking into this issue. I took a look and found the horns on each side. I checked the wiring and it appeared fine and checked out with a meter. I found a replacement OE horn on minimania.com and will pick up one of these (although those Hella ones look awesome, still a possibility) because the high pitch is working great now. Once again, thanks for all of the replies!
Old Jan 20, 2013 | 02:55 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
2nd Gen horns fairly harmonic
Old Jan 20, 2013 | 03:17 PM
Capt_bj's Avatar
Capt_bj
a. why do the cars have different sounds?
b. them ain't horns - these is horns
http://www.stebel.it/stebel2009/prod...logia=musicale
I have River K on the 79
barnoun
Sep 17, 2018 05:04 PM
martinb
Oct 7, 2015 05:00 PM
one73ronin
23
Sep 22, 2015 09:56 AM
trw92a
Aug 26, 2015 01:47 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
