Suspension JCW Left and right rear strut differences?
Old Jan 11, 2013 | 01:26 PM
k_h_d's Avatar
k_h_d
Is there any physical difference in the rear right and left JCW struts? The L and R markings were completely covered and I did not realize that I have installed the L strut on the right side and the R strut on the left side. They installed just fine and everything went back together just right. I was able to finger thread the lower bolt into the control arm about 75% of the way before it got too tight to do by hand. A real close look with a flashlight and I can see the L and R on the struts through the sticker that is covering them...
They look to by identical. The only thing that is really different is that the bracket for the brake lines and ABS lines are grooved on one side. So if you swap them like I did the groove is on the other side now. The brake lines and ABS sensors all plugged in like normal. I have the front left and right on the correct sides, and they are obviously different looking.
Do I need to tear down the rear and completely redo it? I hope not.
Old Jan 11, 2013 | 06:23 PM
k_h_d's Avatar
k_h_d
Everything test drove just fine. Tomorrow I will re-check the torque on the key components and call it done unless someone chimes in saying that the struts are absolutely designed for left and right in the rear.
Old Jan 11, 2013 | 06:43 PM
Braminator's Avatar
Braminator
You should be fine. As you found out they mount exactly the same way.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Toolman
Jan 20, 2016 06:50 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
