R50/53 Battery replacement
Old Dec 16, 2012 | 10:08 AM
dedalus5550's Avatar
dedalus5550
Battery replacement
Just replaced my original factory battery (6+ years, 64,000 miles). I got a Bosch brand at Pep Boys. It fit right and has the little valve that sticks out to connect to a tube (not sure what that is, but it's on the old and new battery so I connected it). However, the metal strap that bolts on over the top (not the plastic cover) doesn't fit. the top of the new battery is somewhat smaller that the main body to almost allow the strap to fit, but the battery is still too wide by about a quarter of an inch and simply won't go on. Is this a common problem? Is there a way to deal with this or is it fine to go without the strap?
Thanks,
Mike Todd
Old Dec 16, 2012 | 01:54 PM
ZippyNH's Avatar
ZippyNH
The tube is to vent hydrogen gas that forms when a battery is recharged...normally it is not an issue, but when the battery is located INSIDE the car, it should be vented to the outside.
The factory tie-downs may/may-not fit various aftermarket batteries, but you should 100% ensure the battery is secure....even a small amount of movement can GREATLY shorten the batteries life...VIBRATION is a batteries biggest enemy.
Old Dec 16, 2012 | 02:32 PM
minsanity's Avatar
minsanity
R53s can fit either DIN55 or 66 batteries.
Old Dec 16, 2012 | 02:37 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
In addition to vibration, please ensure that the battery is securely fastened. If involved in an accident, the battery can be a 30+lb. "missile" that can inflict serious injury or death. Please modify the strap to fit or fabricate one that does.
stevepsd
35
Dec 6, 2022 03:22 PM
woodstudio
Mar 15, 2020 08:28 AM
polotska
Aug 23, 2015 03:03 PM
scottrn
Aug 22, 2015 07:26 PM
jeremy_reyes94
Aug 12, 2015 10:56 AM
