R56 OBDII code says N/A
Old Dec 12, 2012 | 02:03 PM
ShaLor's Avatar
ShaLor
OBDII code says N/A
The check engine light came on in my 2009 Mini Cooper S. I hooked up my Autel MaxiScan OBDII and CAN Compliant reader and it detects a trouble code. The problem is that when I try to see what the trouble code actually is it says: NA where to code should be.
I have never run across this before and am hoping someone here might be able to give me some insight.
Please help.
Old Dec 12, 2012 | 02:14 PM
Slave to Felines's Avatar
Slave to Felines
Probably a MINI-specific code. You may need to have it checked with a BMW or MINI reader.
Old Dec 12, 2012 | 02:16 PM
ShaLor's Avatar
ShaLor
That would really suck, since I bought that scanner because it says it shows vehicle specific codes as well.
Old Dec 12, 2012 | 03:10 PM
bluefox280's Avatar
bluefox280
Are you getting a fault code NUMBER, and not the DESCRIPTION?
If so, you can easily cross-reference the fault code number against the service manual.
If you're not even able to read the fault code numbers at all, the scanner you bought cannot read the specific MINI-protocol.
Look into a Bavarian Technic scan-tool that reads the ECU, and all the specific modules installed on the car (ABS, Airbags, Central Convenience, etc).
- Erik
Old Dec 12, 2012 | 03:12 PM
ShaLor's Avatar
ShaLor
- Erik
Yeah, it looks like I am going to have to get a different scanner. It reads that there IS a fault code, but it is not able to give me a fault code number. It just says N/A
As far as the Bavarian Technic scanner, it looks like I am out of luck there too. It says that it needs a windows based computer to run and I am a Mac user.
Old Dec 12, 2012 | 03:14 PM
bluefox280's Avatar
bluefox280
Yep, return the scanner and make sure you find a new one that accepts MINI's protocol communication.
Generic OBDII scanners are typically a waste on Euro-vehicles as they have limited functionality.
Grab a cheap Window's laptop from Craiglist's.
- Erik
Old Dec 12, 2012 | 04:21 PM
COOP310's Avatar
COOP310
You can install Windows on a Mac using BootCamp to dual boot
Old Dec 12, 2012 | 05:24 PM
SoCal MCS's Avatar
SoCal MCS
Scangauge II reads MINI codes.....
rlp
Sep 11, 2015 03:28 PM
