R50/53 Oil Change Interval Reset
Old Dec 7, 2012 | 05:01 AM
nyckatie's Avatar
nyckatie
I'm considering changing my oil for the first time. If I do, I'd like to be able to reset the 15,000 mile interval so that I can track when it's time for the next oil change.
Any advice on how to do this without taking the car into the deal?
Katie
Old Dec 7, 2012 | 05:40 AM
jhull413's Avatar
jhull413
Is this a new car or just new to you?
Old Dec 7, 2012 | 05:44 AM
nyckatie's Avatar
nyckatie
I have a Mini Cooper S 2006... R53... I think.
Old Dec 7, 2012 | 05:49 AM
cristo's Avatar
cristo
Alliance Member
Older threads for resetting inspection or oil service indication:
https://www.northamericanmotoring.co...-interval.html
https://www.northamericanmotoring.co...e-service.html
Old Dec 7, 2012 | 05:51 AM
submitaweasel's Avatar
submitaweasel
http://new.minimania.com/article/192..._-_02-06_MINIs
Old Dec 7, 2012 | 06:44 AM
Kahnfucious's Avatar
Kahnfucious
Also please do not follow the 15k interval. You will need the special oil filter tool..I got mine off of amazon.
..google Mini Cooper oil change pelican parts . R53 is the cooper s while r50 is the regular cooper.
Just curious where in NYC (given your screen name) are you planning on doing this change? I also live in NYC and feel kind of awkward even popping the hood in NYC...let alone climbing under the car :-)
Also expect some spills and messes...DOT will not look kindly upon you if you spill all over the street..place a tarp on the ground...and have plenty of rags on hand.
Getting the oil filter canister off was a little bit tricky...as was getting it back on. I recommend you also have a breaker bar on hand.
Order an extra oil drain plug..there are a few threads on here stating its not necessary each time but it's better to have one on hand vs not.
Old Dec 7, 2012 | 07:32 AM
prewarkid's Avatar
prewarkid
Dumb question new mini owner. I'm getting change oil light and the mileage indicator started counting down from 5,000. It's now at 4,000 when I start the car. Does this mean the oil needs to be changed in 4,000 miles or is past due by 4,000 to be changed? Sorry to hijack your thread. "related question" Thanks
Old Dec 7, 2012 | 08:47 AM
submitaweasel
It means its 4000 away from the recommended oil change interval...meaning its been 11000 miles since the last change. I'd suggest changing the oil as soon as possible. 15000 miles is insane IMO. I change mine every 4-5k.
Old Dec 7, 2012 | 08:50 AM
prewarkid's Avatar
prewarkid
Thanks GREAT advice I just purchased the car last month time for an oil change ASAP.
Thanks!
Old Dec 7, 2012 | 09:40 AM
submitaweasel
There is a possibility that someone didn't reset it after changing the oil...but I wouldn't take the chance if it were my car.
Old Dec 7, 2012 | 09:42 AM
Eric_Rowland's Avatar
Eric_Rowland
FYI, there is no 'change oil light'. There is a service indicator in the tach, but that always displays upon startup. If you have a red light on, that's not a change oil light, but a warning light that you have low/no oil pressure.
Old Dec 7, 2012 | 09:56 AM
prewarkid's Avatar
prewarkid
Hmmm I'm getting a light says change oil, change oil soon forget the exact verbiage I'll check when I run out to lunch.
2006 r50 hard top.
Old Dec 7, 2012 | 10:49 AM
prewarkid's Avatar
prewarkid
Your absolutely right. I just says "oil service" 3900 miles on the odometer and the service indicator light in the tach goes on as well upon start up as you said.
Still learning the car thanks for your help I appreciate it!
Old Dec 11, 2012 | 10:34 AM
nyckatie's Avatar
nyckatie
Thanks for the great responses. The secret is out... I'm not in NYC any more and my husband is doing my oil changes.
Love this forum. People are so helpful.
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
patpatpat
Aug 27, 2015 07:51 AM
ludedude
Aug 10, 2015 07:16 PM
