'03 MCS has an odd..chattering sound near serpentine
Old Dec 3, 2012 | 12:29 PM
toxictv's Avatar
toxictv
Just bought this '03 MCS with 107k on the clock from an older gentleman. Garage kept, always serviced on time, full records of every single thing ever done to it (including about $6,000 worth of preventative and common issue work), all done at the same shop. Got it for $8,300.
I didn't notice this sound when I purchased the car, but have begun to notice it. Does this hot or cold, some times alternates in pitch or frequency.
Here is a link to the video on dropbox.com.
Old Dec 3, 2012 | 03:44 PM
Nitro Jake's Avatar
Nitro Jake
sounds like the belt. spray it with something water soluble- if the noise changes, its the belt or possibly some debris stuck on one of the pullies.
OR
is the metal tab inside the spring on the tensioner still in tact? it should be attached to the tensioner and not moving. if its detached- its not going to affect driveability but it will affect your wallet
Old Dec 3, 2012 | 03:52 PM
toxictv's Avatar
toxictv
Oi. So that doesn't sound like my supercharger going out to you?
Old Dec 5, 2012 | 11:18 AM
Nitro Jake's Avatar
Nitro Jake
not really. they typically make a much different noise when they go out. I'd be willing to bet theres either some gunk on the idler or tensioner pulley or the belt is just had enough. did you try my advice?
Old Dec 6, 2012 | 02:52 PM
toxictv's Avatar
toxictv
Was putting on some front mud flaps earlier, and I think I may have found the source of that noise:
That stabilizer strut is obviously leaking, and probably not working well, or at all. Any advice? Quick search makes it seem like it's a hard part to get ahold of by itself without replacing the entire tensioner.
Old Dec 7, 2012 | 06:00 AM
buzzsaw's Avatar
buzzsaw
Found this yet to be posted link on our site's data base: https://www.northamericanmotoring.co...er-damper.html. Hope it helps.
Old Dec 13, 2012 | 03:22 AM
sprcpr's Avatar
sprcpr
chattering sound
Just to let you know that almost all of these cars have a bit of a rattle. I have a 2003 with 40k on it and it has made a rattle since almost new. Every Mini S of that age I've ever been around makes that rattle. I don't hear it anymore unless someone points it out.
Old Dec 13, 2012 | 07:47 AM
Helix13mini's Avatar
Helix13mini
I'd have to respectfully disagree with the above diagnoses and remedies. The most common source of a rattling sound in the belt train is either the tensioner or the idler pulley. You can CAREFULLY use a stethoscope or equivalent (prybar, long screwdriver, etc) to localize the noise. It is clear that your tensioner dampener is shot, and it needs replacement, so maybe you'll get lucky and have it turn out that it's your tensioner bearing that's making the noise, and fix both in one shot.
If you're unlucky, you'll discover with your stethoscope that the noise is coming from your supercharger, but that's a post for another day.
A well-maintained R53 should run without rattles. Good luck.
Old Dec 13, 2012 | 01:23 PM
Nitro Jake's Avatar
Nitro Jake
While I agree with your next steps, we still don't know the condition of the belt as he has not yet reported on it.
Furthermore, all of these parts will "make noise." what you're listening for when using this method is a gritty, uneven rhythm caused by a failed bearing.
alistaircookie
Oct 8, 2015 10:52 AM
h0micide
Aug 27, 2015 09:17 PM
h0micide
Aug 25, 2015 12:19 PM
spec35
Aug 18, 2015 07:07 PM
Colt45Magnus
Aug 13, 2015 11:18 AM
