R56 Anyone running 205/40-17 tires?
Hi guys, Found a decent second set of wheels I was planning on picking up for the summer. 17in is where I want to be. I believe I saw a chart with the different stock wheel diameters with different tires/rim sizes, but can't seem to find it.
The set I am looking at has 40s which I am not sure if that would be good or bad. Anyone run 40s before?
I would certainly prefer the stock 205/45 but there is a good deal on a set of wheels that have 40s on them. Was just curious if anyone ran them. I know the wheels are 17x7. I'll check out the pictures, thanks Erik
I've been running 215 x 45 x 17 tires since it was new. The 205's have around a 7 mph speedometer error, thanks to Europe in trying to slow cars down. With the 215's I have about a 1 mph error. I've had this checked by Iowa Highway Patrol radar that they use.
As for going 205 x 40, I think that 225 would work better for you and I've heard of guys running them on hatch's with no problems. Get with TireRack, they are good help.
Halfway down this page on the other forum (that I seldom visit anymore)
http://www.mini2.com/forum/faq.php?faq=faq_wheels_tyres
is this:
On street cars, it should have an overall diameter that is within ±3% of the factory specification.
The ±3% variation is recommended for street cars in order to maintain accurate speed data
going into the computer, thus keeping odometer and speedometer changes negligible.
While a ±3% diameter increase or reduction in tire diameter may sound very limiting,
in most cases it allows approximately a ±3/4" diameter change.
Assuming 24.00" (609.6mm) as the factory specification for overall diameter, any of the following tire sizes may be appropriate:
is this:
TIRE SIZE | DIAMETER
195/55-15 | 23.44in (595.5mm) |
205/40-17 | 23.46in (595.8mm)
215/50-15 | 23.46in (596.0mm)
215/45-16 | 23.62in (599.9mm)
195/50-16 | 23.68in (601.4mm)
185/60-15 | 23.74in (603.0mm)
215/40-17 | 23.77in (603.8mm)
205/55-15 | 23.88in (606.5mm)
215/35-18 | 23.93in (607.7mm)
175/65-15 | 23.96in (608.5mm)
225/45-16 | 23.97in (608.9mm)
205/50-16 | 24.07in (611.4mm)
225/40-17 | 24.09in (611.8mm)
225/35-18 | 24.20in (614.7mm)
195/60-15 | 24.21in (615.0mm)
205/45-17 | 24.26in (616.3mm)
215/55-15 | 24.31in (617.5mm)
195/55-16 | 24.44in (620.9mm)
205/40-18 | 24.46in (621.2mm)
215/50-16 | 24.46in (621.4mm)
185/65-15 | 24.47in (621.5mm)
215/45-17 | 24.62in (625.3mm)
Stock fitments are highlighted
________________________________________
This list leave off at least one commonly used size:
205/55-16 | 24.88in (631.9mm)
Some other good tire and wheel info on the page in the link above,
although a lot is missing or outdated now.
I have 205 40 17's General Exclaims on my car - the speedometer does read off. You'll have a bit more fender gap, and you wouldn't think it would make a big difference, but your car will sit a bit lower. I can just fit the toe of my shoe under the front rubber lip under the bumper. Everyone asks me if I have springs on it haha..
Discount Tire Direct has a calcuator. Top right under info center and then click on tire size calculator. Running these against stock will mean a diference. You don't say what your stock size is but 205/40/17 is not a direct replacement for any stock size tire that Mini uses. This calculator will provide diameter, circumference, width, side wall height and very important.....mph equivalent against the stock tire size.
Kimolaoha
Dec 5, 2020 09:32 PM
ltjpunk7
Sep 6, 2015 07:32 AM
kyungmanpark
Aug 23, 2015 07:26 PM
