2010 MCS R56 Rear Fog Lamps
Old Nov 29, 2012 | 04:57 AM
MikeZZMini's Avatar
MikeZZMini
I'd like to install rear fog lamps in the empty slots in my bumper. Is this something I can do myself? What parts are needed and where is the best place to purchase them? Are there any existing threads on this?
MikeZ
Old Nov 29, 2012 | 08:30 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Here are the lights:
http://www.waymotorworks.com/rear-fo...s-r56-r57.html
The switch:
http://www.waymotorworks.com/rear-fo...7-r58-r59.html
and the panel if you want it for the icon:
http://www.waymotorworks.com/rear-fo...tch-panel.html
The parts are pretty easy to install, but after you put it all in you will need to have the car coded to make them work. You will have to have the dealer or a shop with the coding ability do it.
Old Nov 29, 2012 | 08:58 AM
Chimera's Avatar
Chimera
If you're just worried about filling the holes and not having them actually function as fog lights, you could just get the lights and the add-a-brake light kit from Outmotoring and have them function as extra brake lights.
Old Nov 29, 2012 | 02:35 PM
madmaxxed's Avatar
madmaxxed
I installed mine using the add a brake light kit. Install was a breeze. They act as extra brake lights and running lights.
Old Nov 30, 2012 | 03:21 AM
MikeZZMini's Avatar
MikeZZMini
My only worry is installing the toggle switch and new switch panel. Does anyone know of any threads that show how this is done on a 2010 MCS R56?
Old Nov 30, 2012 | 07:24 AM
Chimera's Avatar
Chimera
It's not a trivial task, requires removing a significant portion of the dash. There is definitely a how-to out there but I can't put my hands on it right now. Then you have to pay the dealer to activate it which is $100+ (requiring a re-flash).
edit : found it - https://www.northamericanmotoring.co...-retrofit.html
Old Dec 6, 2012 | 05:11 AM
MikeZZMini's Avatar
MikeZZMini
Thanks for the info...... Very helpful
Old Dec 6, 2012 | 05:21 AM
richardsperry's Avatar
richardsperry
First thing I'd do it look and see if the wiring for the fog lights is even present. BMW/MINI started cutting all sorts of corners in the 2010 year. Mine doesn't have the fog light wiring or the factory alarm wiring.
Old Dec 17, 2012 | 03:17 AM
MikeZZMini's Avatar
MikeZZMini
Well, The wiring for the rear fogs was there. It was under the ends of a piece of high density foam between the bumper and the body.
I used a pick tool (found a thread on here that showed it) to remove the plastic toggle cover. What I thought was going to be an all afternoon job took about 5 minutes.
Thanks to the users of this forum for their help!!
Anyone know what Mini charges to hook up the computer and activate the toggle?
I'm going to call Crown Mini, Richmond, VA later today.......
Old Dec 17, 2012 | 10:20 AM
MotorWorf's Avatar
MotorWorf
I have Rear Fogs on the Clubman and want to convert to brake/running lights. Anyone have directions on the correct wiring?
Old Dec 18, 2012 | 09:07 AM
madmaxxed's Avatar
madmaxxed
Check either gominigo.com or possibly outmotoring for the install. I believe outmotoring carries the wiring and they might have the diagram for you.
Old Jan 16, 2013 | 12:29 AM
Mr_Mooses's Avatar
Mr_Mooses
i want the fog lights to act as extra brake lights, illuminating red when the headlights are on, and getting brighter when i hit the breaks. will each light flash with the corresponding blinker as well?
also, does the add a break light kit come with instructions for wiring?
lights:
add a brake light kit:
http://www.outmotoring.com/add-a-bra....html?&cat=339
thanks!
Old Jan 16, 2013 | 03:54 AM
madmaxxed's Avatar
madmaxxed
I don't believe they will flicker as directional lights. They will stay on as daytime running lights and brake lights. The wiring kit will come with instructions so you will know which wires to tie into on the harness from the tail lights. I know on my 2010 the wiring was not the same color codes from each side. The instructions color coded the wiring but it was only for one side of my car. Just make sure you use the same pin #s from each harness.
Old Jan 16, 2013 | 01:31 PM
Mr_Mooses's Avatar
Mr_Mooses
Thank you very much.
That's good, i use my blinkers a lot and having the fogs flash too would be a little to "flashy" for my taste. :P
Old Jan 16, 2013 | 02:25 PM
madmaxxed's Avatar
madmaxxed
Add the brake pulsar for a bit more flash!
Old Jan 17, 2013 | 05:54 PM
reeltech's Avatar
reeltech
My 09 MCS is currantly at the dealer getting warrenty work and also codeing for the rear fogs that I installed. $122.50 for the dealer to reflash. Even if you dont hook the lights up, just installing the lights makes a world of differance in the apperance of the car, you will not be dissapointed either way.
Old Sep 14, 2013 | 07:40 PM
Ch28Kid's Avatar
Ch28Kid
Does anyone know what blub is inside the rear fog light?
Old Sep 21, 2013 | 04:24 PM
cerenkov's Avatar
cerenkov
the bulb says:
TOSHIBA 921
12V W16W [SYMBOL] 2I8
A12V18W
Old Sep 22, 2013 | 11:21 PM
Melangell's Avatar
Melangell
When I ordered mine, I didn't include the rear fogs but when I wanted them activated, everything was there, lights, wiring, etc. All Way had to do was install the toggle and do some computer stuff.
Dec 23, 2015 10:36 AM
wkp1219
Nov 13, 2015 07:52 AM
JamJam43087
Aug 16, 2015 02:02 PM
