R56 Maintenance and Service on a Mini
Old Nov 27, 2012 | 08:28 AM
GOC4RT's Avatar
GOC4RT
Hey, just trying to see what's ahead of me in terms of Maintenance.. I keep buying parts to mod the thing and I plan on slapping everything on in the spring.
Anyhow, I would like to know what types of services are expected soon, drive belts, plugs, etc.
I take care of my car a lot. I am very meticulous both interior/exterior and motor.
thanks guys!
Edit: forgot to mention, the car had 98,000km. That's roughly 60,000miles.
The car has had brake service done prior to my ownership.
It's a 2007 MCS
A couple pics since threads are boring without them.
Attached Thumbnails Maintenance and Service on a Mini-image-865949520.jpg   Maintenance and Service on a Mini-image-639361536.jpg
Old Nov 27, 2012 | 09:06 AM
bluefox280's Avatar
bluefox280
All depends what mileage you are at, and what's been previously been taken care of on the vehicle.
Provide us with more details and we'll be glad to get to you the info you need.
- Erik
Old Nov 27, 2012 | 09:44 AM
GOC4RT's Avatar
GOC4RT
- Erik
I edited the post. ^
Old Nov 27, 2012 | 11:13 AM
aznqtboy984's Avatar
aznqtboy984
-Have the timing chain replaced if you havent already
-carbon cleaning (walnut blasting)
-check your oil feed line to turbo (50k-60k is when it starts to fail)
-change your battery if you're still on the original
-Spark plugs at 60k
Old Nov 27, 2012 | 11:27 AM
GOC4RT's Avatar
GOC4RT
-Spark plugs at 60k
Cool thanks!
-I had the chain done. It was after warranty but they saw the car was serviced regularly and accordingly. They decided to still do it free
-ill check the oil line to the turbo! Thanks
-I had that one my list to clean the carbon out.
-battery is good
-Plugs will be a good idea, def on my next oil change in a month or so...
Thanks!!!
Old Nov 27, 2012 | 11:29 AM
jcauseyfd's Avatar
jcauseyfd
The only thing that really should be coming due is changing the spark plugs.
Timing chain, carbon cleaning, oil feed line and battery only need to be addressed if they are experiencing an actual problem.
Old Nov 27, 2012 | 12:16 PM
GOC4RT's Avatar
GOC4RT
Thanks. How would I know about the oil feed line? Any way of checking myself or is it a technicians job mostly? Any symptoms of how I could know its getting clogged?
Old Nov 27, 2012 | 12:21 PM
countryboyshane's Avatar
countryboyshane
You need to change the coolant. It is five years old
Old Nov 27, 2012 | 12:29 PM
jcauseyfd's Avatar
jcauseyfd
The more common problem is that it starts leaking. Evidenced by the drops of oil.
Old Nov 27, 2012 | 12:49 PM
GOC4RT's Avatar
GOC4RT
Cool thanks,
Roughly from what area?
Old Nov 27, 2012 | 07:15 PM
aznqtboy984
check out this thread. I posted a pic of my oil feed line
https://www.northamericanmotoring.co...s-leaking.html
Old Nov 28, 2012 | 04:36 AM
richardsperry's Avatar
richardsperry
Buy a Bentely Service manual. If you plan to keep the car, and do a lot of, or most of your own work. EVERYTHING about service is there.
Sexual Chocolate
Mar 31, 2019 08:02 PM
Dec 23, 2015 10:36 AM
tr3y003
Oct 22, 2015 10:48 AM
minicoclub
Aug 25, 2015 09:07 AM
ludedude
Aug 10, 2015 07:16 PM
