R56 07 justa alignment spec?
Old Nov 23, 2012 | 10:07 PM
yyj3869's Avatar
yyj3869
i had alignment done with two rear new tires replacement from firestone. And they took about like an hour for only rear alignment.
I just test drove on freeway..I almost had an accident because of f**king alignment. steering wheels are moving left to right left to right at 50-70mph.
please see attached and let me know if there is something wrong.
Old Nov 23, 2012 | 10:29 PM
slinger688's Avatar
slinger688
Alignment specs generally look pretty good to me.
Was the car wandering?
Old Nov 23, 2012 | 10:32 PM
yyj3869's Avatar
yyj3869
Yes it was. i was so scared..
Old Nov 23, 2012 | 10:35 PM
slinger688's Avatar
slinger688
Looks like you have two different types of tires from your other thread. Also you may have run flats mixed with non run flats. This can be a bad combo.
yyj3869's Avatar
yyj3869
It also little bit tilted to right side when i leave my hands from steering wheel
Old Nov 23, 2012 | 10:39 PM
slinger688's Avatar
slinger688
That is easy for them to fix.
Old Nov 23, 2012 | 10:44 PM
yyj3869's Avatar
yyj3869
i dont have any run flat tires but i have 2 front continental tires that has some thread left and 2 new rear bridgestone tires that was installed today. they are only non run flats
Old Nov 23, 2012 | 11:09 PM
slinger688's Avatar
slinger688
This can be rather difficult to diagnose from afar without driving the car.
I used to have a car that tramlined a lot due to tires. Not sure if that is your issue here.
Old Nov 24, 2012 | 03:38 AM
r34king's Avatar
r34king
if the front end shakes at highway speeds have them balance the tires and check the front end for any worn/broken parts. If all else is good I'd say you have a bad tire. The alignment specs seem good. If the car pulls to the right, most likely a bad tire. If the steering wheel is crooked, most likely it was a little off center when they did the alignment
Old Nov 24, 2012 | 04:35 AM
richardsperry's Avatar
richardsperry
As I said in the other thread, BUY A SET of tires. You have 2 tires from one manufacturer, and 2 from another. I told you htey may not get alone with each other.
A long time ago, I put 2 snow tires on the back of my RX7 and 2 reg tires in from. I thought I was going to die in the first 30 seconds. I learned my lesson.
DON'T MIX tire manufacturers or really even different models form the same manufacturer.
Old Nov 24, 2012 | 10:29 AM
Tio Barry's Avatar
Tio Barry
Number one. New tires have all sorts of finshing compounds that will make them feel greasy. You may be mistaking front end tracking for rear wheel sliding. Could take a month to scrub of the surface
Old Nov 24, 2012 | 10:59 AM
yyj3869's Avatar
yyj3869
i took my car to firestone again and they testdrove it and they noticed that something was wrong. After rotation, tire issue is cleared but not sure about alignment.
Old Nov 25, 2012 | 07:02 PM
Slave to Felines's Avatar
Slave to Felines
The numbers look reasonable. Could there be something they didn't tighten back down again after adjusting? Are the tire pressures even and in a sane range?
Old Nov 26, 2012 | 09:57 AM
Jim Michaels's Avatar
Jim Michaels
I agree with the posts that your alignment looks good, and that the front/rear tire mix is probably the main suspect. That plus the somewhat slippery release agent on the new tires that takes 100 to 200 miles to fully wear off.
Old Nov 27, 2012 | 04:39 AM
richardsperry
It doesn't take anywhere near 100 miles... Complete hogwash. Otherwise race cars, and auto cross cars would crash right away... And what fun would that be?...lol
Now that they rotated the tires and the feeling when away when driving straight, it will show up sometime later when you aren't going straight.
You have mismatched tires. At some point it's going to haunt you...
Old Nov 27, 2012 | 09:03 AM
condor27596's Avatar
condor27596
It is all good advice. You should move toward getting a set of matched
and in good condition tires. The cars have a short wheelbase and are not
that heavy. It's not like driving a Buick whatever with wrong tires.
It actually does matter.
I can tell on my CRX if a tire is off by 2 lbs of air because it pulls.
You should not scrimp on tires and brakes, the life you save could be mine (or yours!)!
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Keet
Suspension
Aug 30, 2016 03:46 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
gnhovis
Sep 28, 2015 10:56 AM
