Suspension Review and Detailed Install: H&R Spring Install for Mini Countryman
Old Nov 12, 2012 | 11:56 AM
xenor's Avatar
xenor
This thread will document the installation and review the H&R Springs for the 2wd Mini Countryman S.
The vehicle these will be going on:
Manufacturer: H&R
Part Number: 28923-1
Approx. Front Lowering: 1.4"
Approx. Rear Lowering: 1.4"
Ordered from MotoringWerks.com
Unfortunately, UPS was a little overzealous with the package. A spring was lost in transit.
Fortunately MotoringWerks is sending a replacement spring, and taking the issue up with UPS. Their customer service was fantastic and they responded to my emails over the weekend, during closed business hours. By Monday morning, they had me a replacement spring in the mail and have supplied a UPS tracking number.
The remainder of this thread will be edited once the install occurs.
xenor's Avatar
xenor
The installation was pretty straight forward. I mostly used the Alta tutorial pdf found on this site, but there were a few things that were different. Since the process is pretty well documented and being a relative novice I don't want to provide a guide with misinformation on the process, I will outline some issues I ran into, provide some tips that helped me, and list the tools I used for the job.
Tools used:
13mm Socket (strut tower guide nuts, rear strut top mount bolts)
10mm Socket (xenon leveler sensor arm)
Part MN2122 - Specialty Double 21 & 22 mm Strut Nut Socket
Part MN3424 - Strut Spreader Bit
3/8" 6mm Allen Socket (for front strut shaft, use with MN21222)
5mm Allen Socket (for rear strut shaft)
16mm Box Wrench (for rear strut shaft nut and sway bar link nut)
T30 Torx Socket (for front sway bar link)
18mm Socket (pinch bolt
21mm Socket (rear lower strut nut)
3/8" Torque Wrench (for lower torque settings)
1/2" Torque Wrench (for higher torque settings)
3# Mini Sledge/Mallet
1/2" Brass Drift
Breaker Bar (for rear lower strut nut)
PB Blaster (for strut knuckle and other stubborn bolts/nuts)
Blue Loctite (for 13mm strut guide nuts and 13mm rear strut top mount bolts)
Anti Seize Lube (for front strut pinch bolt)
Spring Compressors
Make sure you disconnect the headlight leveler sensor on the front lower control arm before you start removing the front strut. I'm not sure, but I think it could be damaged when moving the arm/knuckle downward from the strut. Use a 10mm socket or wrench.
The front strut pinch bolt must be removed completely. This bolt did not spin freely on one side once loose, it had to be screwed out with a ratchet. Once removed, install the strut spreader tool in the knuckle gap below where the strut tab sits, so as not to pinch the strut tab with the spreader tool.
Once you remove the pinch bolt (18mm), and install the strut spreader, you can try moving the knuckle downward on the strut shaft. It should be relatively loose, but still tight enough to bind, so you might need to use a brass drift and a hammer to knock the knuckle downward. Once it's almost out, you can remove the 13mm guide nuts and work on removing the strut. It will be difficult to navigate the strut out of the wheel well. I think we went downward next to the knuckle to free up the top, then moved the top outward.
You're left with this once it's out.
Compress the spring, it would help to have an impact gun here obviously. I don't have one, so my buddy and I used ratchets.
It was a must to have the metalnerd strut nut tool. You might be able to do it with an impact gun, but you're going to spin the shaft of the strut and I'm not sure if that's good for the strut.
Make sure you remember the order of the washers and pieces on the front strut hat. I did not cut the bumpstops on the front strut for the reinstall.
You won't need to compress the H&R spring to reinstall on the strut. It's short enough that you can push on it with one hand and start the strut shaft nut.
Use some anti seize on the pinch bolt during reinstallation.
I used some blue loctite on the 13mm guide nuts during reinstallation, just in case.
The rear springs are easy, much easier than the front. Remove the lower strut bolt (21mm) with a long ratchet or breaker bar. I suggest using PB blaster on this bolt and letting it soak.
The top bolts are pretty easy to get to with an extension.
Once everything is loose, this will fall, and it's heavier than it looks. Just be prepared.
I cut the first nub off the rubber bumpstop in the rear.
Old Nov 24, 2012 | 05:13 PM
Shoe Coupe's Avatar
Shoe Coupe
updates?
Old Dec 6, 2012 | 06:43 PM
rayzmini's Avatar
rayzmini
Question any new pics or updates?
did u get your springs in yet?
Old Dec 6, 2012 | 07:29 PM
submitaweasel's Avatar
submitaweasel
LOL I worked for FedEx Ground for a while as a loader. I can say, most employees do not give a **** about what happens to your package. I was one of the few that tried to treat them as though they were my own...only saw 2 other employees in the entire hub do this...and I worked at the largest FedEx Ground hub in America...sucks but when you're getting $10/hr and have to load 400+ packages per hour most people don't take any care.
Old Dec 7, 2012 | 06:38 AM
xenor's Avatar
xenor
I got the springs. Complete set now. My wife had our second born on the 3rd, so it might be some time before I can install them.
Old Dec 24, 2012 | 09:54 AM
xenor's Avatar
xenor
Ok, I finally got time on Saturday to install the springs. I was able to do it myself with the help of a friend, in my garage. I had bought some of the specialty tools necessary for the job (metalnerd strut spreader tool, metalnerd strut nut tool). I will document the installation with a few of the pictures that I took later, but for now, I'll just quickly review the springs from my experience over the last two days.
My CM did not have the Sport Suspension. That said, the ride quality hasn't changed much. It is firmer, but not harsh over bumps, and body roll has been noticeably reduced, even with the smaller non-sport suspension sway bars. The vehicle would still benefit, in my opinion, to an aftermarket upgraded rear sway bar.
I have not yet had the vehicle aligned. I want to let the suspension settle before I get it aligned. There is quite a bit of negative camber on the rear end. I estimate over -2 degrees. I hope an alignment can get it back close to stock, however, I think aftermarket adjustable rear control arms are going to be required to get the alignment to appropriate specs.
I will likely put a few miles on the car as-is, a couple more days (after xmas), and try and procure some control arms before I get it aligned.
Old Dec 24, 2012 | 11:45 AM
Shoe Coupe's Avatar
Shoe Coupe
nice! Just to give you an idea, my rear camber was -2.7 with the NM springs before I got the alignment.. you will most certainly need the camber arms, and at that they can still only get it close to factory.
Old Dec 25, 2012 | 03:25 AM
xenor's Avatar
xenor
Shoe, did you get the control arms right away? I'm going to get them, probably the H-Sport ones, but might have to wait a week or two.
Old Dec 25, 2012 | 02:31 PM
Shoe Coupe's Avatar
Shoe Coupe
no, I was lazy about it and drove around with the factory stock alignment for a couple thousand miles. The car tracked perfectly straight, but then it started pulling to the left when i got rid of my run flats and got the khumo 4x's. That's when I got the arms and got an alignment
I went with the SPC ones. My family is in the auto parts distribution business, so If you'd like a set, PM me, I should be able to get you a good price on those.
Old Dec 25, 2012 | 06:29 PM
xenor's Avatar
xenor
I'm debating on getting it aligned and letting the shop get it as close as they can, and getting arms later, OR getting arms, waiting a week, then getting it aligned.
Old Dec 26, 2012 | 10:39 AM
Shoe Coupe's Avatar
Shoe Coupe
they wont be able to get it anywhere near specs. There's no reason to do it twice, it's a waste of time and money. I drove around for 2000+ miles before doing the alignment and there was 0 extra wear on my tires.
Old Dec 26, 2012 | 10:51 AM
xenor's Avatar
xenor
Agreed. No reason to do it twice. I ordered HSport links from Way Motor Works. I will get it aligned in the next week or two.
Old Dec 28, 2012 | 02:30 PM
cm.d's Avatar
cm.d
Do you have pics of what it looks like lowered? Is the rears only a quarter inch lower while the front is 1.4 inches lower?
Old Dec 28, 2012 | 03:36 PM
xenor's Avatar
xenor
I don't have a after pic yet. I was going to go to the same spot I took my before pic.
I can say that the drop does not look how you described. If anything the front appears a little higher than the back. After it has settled, it's looking quite even front to back. The rear has quite a bit of negative camber now, and once I get that resolved, it should look even more even front to back. H&R states the drop is 1.4" front and rear on the FWD countryman, and that seems accurate.
Old Dec 28, 2012 | 03:38 PM
xenor's Avatar
xenor
Edited original post, rear is lowered 1.4".
Old Dec 28, 2012 | 03:47 PM
cm.d's Avatar
cm.d
Do you bottom out in the rear? I see that a lot of the nm guys are complaining about that. Is the ride stiff? I like a stiff ride (had a STi).
Old Dec 28, 2012 | 04:35 PM
xenor's Avatar
xenor
No bottoming out at all. I did cut my bump stops in the rear, they *might* bottom out and rebound if you didn't. I did not cut them in the front. The ride is as smooth as my stock non-sport suspension. It is more firm, but not harsh.
The bouncy rebound that some of the NM spring owners are noting is not present in these springs. Large dips in the road are more pronounced, but this comes with firmer springs.
I had H&R SuperSport springs and Bilstein Sport shocks on my last car, a 2008 GTI, and this ride it a bit less harsh, probably due to the stock shocks.
Old Jan 1, 2013 | 12:29 PM
Bakerbrdz's Avatar
Bakerbrdz
Anybody got pics of these installed? Before and after?
Old Jan 1, 2013 | 03:10 PM
xenor's Avatar
xenor
Working on it. It has been gross and rainy here and I was waiting to get an alignment to correct the camber in the rear. I hope I can take some this coming weekend.
Old Jan 2, 2013 | 11:39 AM
Shoe Coupe's Avatar
Shoe Coupe
Xenor, Can you actually post what the rear springs look like installed?
I want to see how many dead coils the H&R setup has vs the NM.
If the H&R springs give a better ride than the NM, I might go that route rather than coilovers.
Have you had rear passengers in the car? Has it bottomed out at all with rear passengers?
Old Jan 2, 2013 | 05:28 PM
xenor's Avatar
xenor
I have had one big fellow in the back seat after the springs. No harsh rebound and no bottoming out. My bumpstops on the rear are cut. I can take a pic of the dead coils.
Old Jan 3, 2013 | 09:45 AM
xenor's Avatar
xenor
I got the alignment done today. Needed it. Over 3 degrees of negative camber in the rear.
Old Jan 3, 2013 | 05:16 PM
rayzmini's Avatar
rayzmini
Talking nice
so this is without the rearadjustable control arms ?
Attached Thumbnails Review and Detailed Install:  H&R Spring Install for Mini Countryman-eeb528e5-fb1c-43ef-8640-3120377ff160-7055-000003388c33a5fb.jpg
Old Jan 3, 2013 | 05:17 PM
Shoe Coupe's Avatar
Shoe Coupe
no that's with the arms. The max you can go on camber with the SPC arms is -1.7
