R55 Tpms
Old Nov 4, 2012 | 07:37 AM
minisisco's Avatar
minisisco
Tpms
When changing tires is it needed to replace the TPMS system?
Old Nov 4, 2012 | 08:24 AM
CR&PW&JB's Avatar
CR&PW&JB
The TPMS sensors are not in your tires, they're on your wheels. So swapping out tires does not require you to replace them, no.
Old Nov 4, 2012 | 09:29 AM
minisisco's Avatar
minisisco
So why is America's Tire charging $14 a tire when they change them?
Old Nov 4, 2012 | 09:33 AM
CR&PW&JB's Avatar
CR&PW&JB
Probably to reset them. Did you ask them?
Old Nov 4, 2012 | 10:00 AM
minisisco's Avatar
minisisco
"Manufacturers recommend that you replace the wearable components of your TPMS sensors each time a tire is replaced or serviced. These wearable components are provided in our TPMS Rebuild Kits.
Warning: Using standard valve stem parts in your TPMS Sensor will damage the sensor."
From the web site. Is it ok to change the tire without replacing the TPMS?
Old Nov 4, 2012 | 10:17 AM
CR&PW&JB's Avatar
CR&PW&JB
Opinion. For $14, if that's what they are charging for, let them swap them out, IMO.
Having just shopped around for a tire shop, I can tell you nearly every one charges $10-15 extra for each wheel with TPMS.
Old Nov 4, 2012 | 10:21 AM
minisisco's Avatar
minisisco
Thanks for the advice.
Old Nov 5, 2012 | 10:31 AM
6thGear's Avatar
6thGear
Its for the "rebuild kit" since they cant use regular valve stems and innards on a TPMS. Retail price looks about $9 per wheel:
http://www.ebay.com/itm/TPMS-Valve-K...ff1101&vxp=mtr
Tires without TPMS can get new valve stems at about $1-2 per wheel. Valve stems are usually replaced with each new tire because of exposure to elements and usage wear from inflating tires
Old Nov 5, 2012 | 06:19 PM
slimjimtell's Avatar
slimjimtell
The valves are pressure fit...CHANGE them any time you remove the tire from the wheel, They will aquire leaks if you don't.
Old Nov 10, 2012 | 06:16 PM
Price's Avatar
Price
No, don't change EVERY time, and no they won't.
Old Nov 11, 2012 | 05:24 PM
slimjimtell
Anytime you remove the valve to let the air pressure out when changing tires, you should replace it with a rebuild kit. They're cheap and keep out the leaks!
You can choose not to, your call.
Old Nov 12, 2012 | 04:15 AM
Price's Avatar
Price
Replacing valves is a standard procedure when working with tires and is usually included in the cost of 'mounting and balancing', along with balancing weights, etc.
This, however, has nothing to do with 'TPMS Rebuild Kit' that installers charge you extra and when the inner rubber gasket and locking nut and washers are replaced every few years... and while the gasket may lose its sealing qualities due to loss of elasticity and degradation, in case of the locking nut it's due to surface corrosion and in 99.99% cases purely cosmetic.
freckles81
Jan 15, 2017 06:33 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
Doc Pain
Sep 15, 2015 11:31 PM
PSU 98
Sep 11, 2015 11:20 AM
renchjeep
Sep 6, 2015 01:54 PM
