HELP! Broken Coolant Plastic Pipe
Old Oct 31, 2012 | 08:23 AM
x SPUD x's Avatar
x SPUD x
So my thermostat housing went out. Started replacing it tonight, and forgot there was a clip (#3) holding the back section to the pipe below:
Ended up breaking the opposite end of the pipe that connects to the water pump.
Anybody have any instructions on replacing that pipe or getting access to the water pump end? (pieces and o-ring are still inside)
I don't have a Haynes manual, nor will be able to get one. Any help is appreciated. Thanks!
BTW it's an '07 R56 S
Old Nov 5, 2012 | 05:45 PM
boOst spIKe's Avatar
boOst spIKe
Do you want the BMWNA/MINIUSA way or, Flat Rate?
Old Oct 5, 2013 | 06:26 AM
Milestone707's Avatar
Milestone707
I am in the same predicament. How did you go about dealing with this problem? Did you have to remove the water pump to get to the broken piece or did you remove the intake manifold to get to it?
Old Oct 7, 2013 | 01:54 PM
To remove it you will have to remove the thermostat housing and then you can reach it from under the intake manifold. You will be able to then see the connection to the back side of the water pump housing.
#1 Water Pipe Part # 11537589713
http:/www.ecstuning.com/Search/SiteSearch/11537589713/
#3 Clip - Priced Each Part # 11537548652
http://www.ecstuning.com/Search/SiteSearch/11537548652/
Water pipe connects to back tube on the thermostat housing. Lower tube in pic which reaching around the back.
See this thread for the removal of the thermostat housing. Then you can get to the water pipe.
https://www.northamericanmotoring.co...hermostat.html
And here is the OEM MINI Coolant , just mix it 50/50 with distilled water for your refill o your coolant.
MINI Anti-Freeze / Coolant - 1 Gallon ( 3.79L) Part # 82140031133
http://www.ecstuning.com/Search/SiteSearch/82140031133/ES196253/
Thanks and good luck.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
shorenetworks
Nov 4, 2019 06:18 PM
jef1f
Sep 18, 2015 02:49 PM
OutMotoring
Sep 8, 2015 06:27 AM
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 7, 2015 07:51 PM
