Bought my first Mini but need to replace some things...help
Old Oct 28, 2012 | 07:34 PM
cincystephen's Avatar
cincystephen
I just bought a 2010 MINI Clubman S. I knew up front that it needed new tires and break pads. Do I replace the run flats with run flats or something else? They are 16". Best place to buy break pads and what brand?
Old Oct 28, 2012 | 07:40 PM
CR&PW&JB's Avatar
CR&PW&JB
Ditch the runflats. You'll be glad you did.
Tons of info can be found on here re: brake pads. Largely a matter of opinion and what fits your driving style and needs/priorities.
Call the Tirerack. They can help you with your decisions on tires and pads. And most swap out rotors with the pads, BTW.
Old Oct 29, 2012 | 09:15 AM
cincystephen
tires
I am thinking about just getting a set of tires for winter and then worry about replacing my tires when it gets warm in April after reading through the forums. I found these tires on craigslist that are the same size as mine are right now. They are from a 2006 convertible MINI S, how do find out if the rim layout fits my 2010 clubman s?
http://indianapolis.craigslist.org/pts/3354291511.html
Old Oct 29, 2012 | 09:32 AM
Fly'n Brick's Avatar
Fly'n Brick
Unless you need another set of rims, I see no value in the craigslist deal. Tire rack can get you outfitted with a set of winter tires for around $100.00 +/ - a corner. I just had a new set installed at an allignment shop and the guy charged me $10.00 a corner to mount and balance. Do a little more shopping before you jump in. No need to spend bucks where you don't need to.
Here's what I found on Tirerack: http://www.tirerack.com/tires/TireSe...55&diameter=16
Old Oct 29, 2012 | 09:50 AM
cincystephen
but wouldn't it make sense to have winter tires on a set of rims and get some high performance summer tires for my current rims that need the runflats replaced? So I then have and extra set of winter tires on rims for what 4 winter tires almost cost alone.
Old Oct 29, 2012 | 10:49 AM
trakatdave's Avatar
trakatdave
The 2010 clubman uses larger diameter lug bolts and will not fit into the 2006 wheels.
Old Oct 29, 2012 | 10:51 AM
cincystephen
Where can I go to find what years do?
Old Oct 29, 2012 | 10:58 AM
CR&PW&JB's Avatar
CR&PW&JB
Second generation MINIs start with model year 2007. Wheels from a first gen will not fit a second gen. Pretty sure Countryman wheels will not fit on your vehicle but any other wheels from MINIs built on or after 2007 should.
Old Oct 29, 2012 | 11:04 AM
cincystephen
thank you so much, that should help me while shopping on craiglist and ebay. I have so much to learn about the MINI Cooper world. But I love my car!!!
Old Oct 29, 2012 | 12:35 PM
Tio Barry's Avatar
Tio Barry
OP's plan makes a lot of sense. Just remember you will need a place to store the wheels out of season, you can probably get a less expensive winter set, most wheels will accept the 14mm lug bolt - bring one along when you look at the clist set. I am using gen1 wheels on my 2010.
Old Oct 29, 2012 | 12:40 PM
cincystephen
so you think the 2006 may fit? I just thought that was a great price for newer tires with rims to use during winter.
Old Oct 29, 2012 | 03:16 PM
PatM's Avatar
PatM
You will also want to add TPMS sensors to the new set of wheels. Make sure you buy the right ones. They are not all interchangeable. This will also add cost to your plan. That being said I use the stock wheels as my winter wheels and have another set of wheels much lighter than factory stock for my summer tread. It works well for me. This way I can rotate the tires myself and change from one set to another in my garage. I do this for both of our cars.
Old Oct 29, 2012 | 06:50 PM
kukaepe's Avatar
kukaepe
MINI changed from a 12 X 1.5 mm lug bolt to a 14 X 1.25 mm lug bolt midway or so through 2006. I agree with Tio Barry that MINI factory wheels will work on both lug bolts, I've read that in numerous places and have 3 sets of MINI factory wheels that work fine with my 14mm bolts. Pat M makes a valid point regardless of what additional wheels you may obtain, you will need to have the proper coordinated TPMS sensors installed in the wheels unless you want to look at the warning light. Fortunately my '07 MCS uses the early style system that uses rubber valve stems. Just thought I would share a bit of info, good luck in your hunt.
Old Oct 29, 2012 | 08:38 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Ditch the runflats
For Brake pads go with the EBC Redstuff we've had great luck with them.
Old Oct 30, 2012 | 06:02 AM
cincystephen
would it be unheard of to just not put the tpms sensors on my winter tires and live with the light on in car Nov-Feb?
Old Oct 30, 2012 | 07:05 AM
Tio Barry's Avatar
Tio Barry
Yes. Again your logic is correct. The little light stays on in the center (easy to ignore) and you should check the air in your tires manually evey couple of weeks. You can also save a couple hundred dollars skipping the add'l sensors.
Old Oct 30, 2012 | 11:20 AM
cincystephen
sorry if this is another dumb question... does the break sensor come with the break pads when you buy them? do the sensors always need replaced with changing the pads and rotors if they don't come with the rotors or pads? Is the old one bad or does it go bad by breaking off and setting off the brake light? My understanding is that it's one sensor front left and one sensor back right on 2010 clubman s
Old Oct 30, 2012 | 11:35 AM
jcauseyfd's Avatar
jcauseyfd
The sensors are sold separate. If you have tripped the sensor, then it will have to be replaced to clear the light. It is more than a simple on/off circuit. If you have started to get into the actual sensor part, it is considered "tripped".
It is possible for the sensor to go bad, but not very common. You are correct on the locations.
Old Oct 30, 2012 | 11:42 AM
cincystephen
so if the front pads are setting it off, I only have to buy a front sensor as long as I change the back before it gets the sensor. Thank you for the reply.
Old Oct 31, 2012 | 09:29 PM
RobertJ's Avatar
RobertJ
I just bought both front and back brake pads from Rock Auto. They were a Monroe kit and came with pads, clips and sensors for a very good price. If you feel you need performance parts go with some of the suggestions above, but if you use your Mini like 90% of us check out Rock Auto for a deal that includes the sensors.
Old Nov 1, 2012 | 07:57 AM
cincystephen
thanks man, i like the prices on rockauto, but i can't find the packages you got, only the individual parts.
Old Nov 3, 2012 | 06:26 AM
RobertJ's Avatar
RobertJ
Sorry, I've been traveling and just saw your response. Here's the part numbers and prices:
MONROE DX1204W Brake Pad $42.79
MONROE DX1309W Brake Pad $36.79
These come with needed clips and sensors.
Alkaidovich
Jan 30, 2021 01:35 AM
tr3y003
Oct 22, 2015 10:48 AM
kitty90034
Navigation and Audio
Aug 25, 2015 12:47 PM
cjsdad
Aug 11, 2015 08:46 AM
nomar116
Aug 10, 2015 11:24 PM
