R55 Coolant Leak
Old Oct 27, 2012 | 10:22 PM
minisisco's Avatar
minisisco
Coolant Leak
Any body have issues with coolant leaks?
Old Oct 28, 2012 | 03:44 AM
twocute's Avatar
twocute
Yeah, I've had a pinhole leak in the radiator in my '04 S. Been driving around with it for almost 5 years now. Done driving schools and trips to Florida with it. I just top it off once in a while. It still holds some pressure and if I leave the cap not fully tightened I don't have to add as often.
Old Oct 28, 2012 | 04:33 AM
MyroMini's Avatar
MyroMini
Yes. Had my thermostat housing replaced a few weeks ago because of that
Old Oct 28, 2012 | 07:02 AM
byron h's Avatar
byron h
Coolant leak
I took my 2011 MC in for a water leak at the connection of the water hose to the thermostat housing. The hose with the water leak was replaced with a hose that is part of the coolant temperature sensor recall. The cooling system was pressure checked and I have not lost any coolant in about 400 miles after this work. My coolant level stayed at the high mark in the overflow tank before the leak occurred.
2011 MC PW/B
Old Oct 28, 2012 | 07:32 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
Yes, the thermostat housings.
Chad
Detroit Tuned
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Oct 28, 2012 | 08:29 AM
minisisco's Avatar
minisisco
What was the cost?
Old Oct 28, 2012 | 04:14 PM
MyroMini's Avatar
MyroMini
Originally Posted by minisisco
What was the cost?
can't say, it was covered under warranty
Old Oct 28, 2012 | 05:13 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
no.
Old Oct 29, 2012 | 07:16 AM
minisisco's Avatar
minisisco
Just dropped off at the dealer... Will keep you posted.
Old Oct 29, 2012 | 07:40 PM
minisisco's Avatar
minisisco
It appears to be covered by the 7 year 70k warranty
Old Nov 1, 2012 | 04:02 AM
Newfman's Avatar
Newfman
Water pump. 52,000 miles. $690. Getting done today. Soooooooooo, not happy.
Old Nov 1, 2012 | 08:02 AM
Prost's Avatar
Prost
We have a 7yr/70k powertrain warranty?
Old Nov 1, 2012 | 05:44 PM
minisisco's Avatar
minisisco
We have a 7year 70k Mile emission warranty
Old Nov 1, 2012 | 05:52 PM
minisisco's Avatar
minisisco
From my understanding we had some sort of recall on the water pump, did you check that out?
shorenetworks
Nov 4, 2019 06:18 PM
debitsandcredits
Sep 21, 2015 08:34 AM
rikaro
Sep 21, 2015 06:57 AM
olson187
Sep 18, 2015 10:26 AM
mimaal
Sep 4, 2015 09:09 AM
