R56 Help with center console where the shifter is.
i am trying to take the center console out. I am hung up on the wireing
there is a molex plug that plugs in to a plasic piece. the wires go to thw
sport button and the DTC. For some reason i can't get it to come apart.
That is what I thought but no luck . I am trying to take it out because I want to install a radar kill button in the middle of the sport and the dtc button. But it is killing me I can't get it off. I wish someone had a DYI on it but no luck so far.
Did you get it? I have had to do this twice and still haven't figured out the "trick." The best that worked for me was a flashlight, a mirror, and a very small screwdriver to push in each side one at a time.
No not yet flash light and a mirror trick I used as well. I have given up for the night but tomorrow I will be back at it. I mean it has to come off of there right?
Yeah it will come off it is just a pain in the ***. I have only done mine once. That whole center console is just a **** my life piece.
Well I guys I finally got it. It has two dog ear clips on the side of the clip. I finally took the back of the console where the parking brake is. Which by the way was a lot easier to get out than I had thought. But once I had that off i could get to it and it came right off. I hard wired my radar in but I wanted to a way to turn it off just in case I was getting a ticket. But here is the picture it works great by the way. I know it looks dirty but i took this right after I got it together. thanks for the help guys or at the very least the encouragement.
Glad you figured it out. Had a similar idea for that button.
On mine, wiring was long enough to work the console out of the shifter and hand brake & flip it over. From there it was easy to release the clips.
I put the subwoofer control **** on top of the middle button & wired the led indicator to shine on the small storage
Windman and rederik, both of your mods to the "dead button" look very sharp.
Wish I had the skills to do something like that, although I'm not sure what I'd put there. Another aux input or something?
Thanks!
I have a Bass600 in the boot, it came with a remote level control with a bright led indicator. I disassembled it and noticed that it was just the right size to fit in button. I extended the wiring for the led & drilled a hole in front of the cig plug.
I don't consider myself skilled either, I'd say anyone can do it.
xraycat
Aug 12, 2015 02:36 PM
