Suspension Spring change
Old Oct 11, 2012 | 08:31 AM
Mootsdog's Avatar
Mootsdog
Spring change
Going to be lowering my 06 MCSC with TSW V3 springs. Can I replace the springs without completely removing the strut assembly. If so is there a how to somewhere.
Old Oct 11, 2012 | 10:18 AM
blue2turbo's Avatar
blue2turbo
Not that I know of, even if you managed to get the upper strut mount off and the spring free, the control arm/knuckle isn't going to lower enough for you to get the spring lifted off the strut without dropping the whole thing.
It's not difficult at all to remove the entire strut assembly. It's only the pinch bolt, end link nut and the 3 nuts on top.
Old Oct 11, 2012 | 12:55 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
It really isn't; have a look for yourself if you're not familiar with the process:
Front:
http://www.pelicanparts.com/techarti...eplacement.htm
Rear:
888.280.7799 | 6am - 5pm PST
Old Oct 30, 2012 | 06:21 AM
SneedSpeed's Avatar
SneedSpeed
You have to remove the whole assembly both front and rear to change the spring.
Old Oct 31, 2012 | 07:56 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
No need to purchase an expensive spring compressor either. Just buy a pair of 1" wide ratchet straps from Harbor Freight. After you get the struts out, just tighten the straps on either side of the spring to put it in compression before you undo the top nut. Then carefully release the ratchets once you've gotten the spring out. Put the new spring in compression with the straps and re-assemble. Be sure to line up the ends in the perches properly before releasing.
Old Oct 31, 2012 | 08:31 AM
submitaweasel's Avatar
submitaweasel
Or you could always rent one from a local auto parts store...I had to give a $52 deposit on one at O'Reillys and when I returned it I got $52 back...all it cost me was a 5 minute drive.
Old Oct 31, 2012 | 11:34 AM
OldGameFreaK's Avatar
OldGameFreaK
OR go spend 15.00 at Harbor Freight and get the right tool for the job. http://www.harborfreight.com/macpher...-set-3980.html
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
surfblue
Oct 24, 2018 01:20 AM
melscoop
Mar 30, 2016 06:56 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
