R56 Thermostat housing
Old Oct 8, 2012 | 02:30 PM
Rwynne's Avatar
Rwynne
Thermostat housing
I noticed in my garage,a small puddle of water under my car.I have a 2007S,and am wondering if the therostat housing leak I have read about(or better,warned about)has become an issue.The water is the consistency of a water,anti-freeze mix.Any help and or suggestions would be greatly appreciated.
Happy motoring,
Rwynne
Old Oct 8, 2012 | 06:42 PM
Mini2na's Avatar
Mini2na
It sounds like antifreeze mix. Where is the puddle? Most likely the thermostat housing or the water pump, but it could be a hose. You're going to have to a bit of detective work to get an answer, but.... it needs to be taken care of no mater what the culprit is.
Old Oct 8, 2012 | 06:55 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If it's leaking more on the driver side it is more than likely the thermostat assembly.
http://www.waymotorworks.com/thermos...5-r56-r57.html
that is the most popular leak, but we have seen some water pumps leak too.
Old Oct 8, 2012 | 07:02 PM
bigsmittyJAS's Avatar
bigsmittyJAS
Just something to check: I had a CEL that I thought was the temp sensor on the thermostat assembly (turned out to be the T stat stuck), but anyhoo...I tried the sensor first and when I removed the old sensor, the oring was almost non existant. I still don't know how it wasn't leaking The sensor is pretty easy to get to and that might be something to check first.
nighthaw2k
Sep 30, 2015 01:51 PM
YoloSapien
Sep 25, 2015 07:12 AM
cjny
Sep 21, 2015 01:28 PM
rikaro
Sep 21, 2015 06:57 AM
MiniLes
Sep 18, 2015 07:09 AM
