Suspension Free Camber, anyone ever have the shocks shift?
Old Oct 8, 2012 | 12:41 PM
Mindspin311's Avatar
Mindspin311
I was thinking the other day, has anyone had the shocks shift on them after doing the free camber mod?
Old Oct 8, 2012 | 12:56 PM
slinger688's Avatar
slinger688
No, mine has stayed put.
It is pretty well torqued, perhaps a little more than is required.
Old Oct 8, 2012 | 12:58 PM
slinger688's Avatar
slinger688
Forgot to mention, I do check it at least once a year as part of my suspension inspection.
Old Oct 10, 2012 | 06:37 PM
Mindspin311
Im going to take some measurements and see if there's something I can come up with the lock everything in place.
I work at a prototyping company, so I have access to a bunch of 3D printers to knock out some plastic versions.
Old Oct 10, 2012 | 06:54 PM
slinger688's Avatar
slinger688
Sometimes painted surfaces can be bad to hold bolts in place. Just a thought.
I would also consider blue loctite and perhaps a better lock washer.
Old Oct 11, 2012 | 07:41 AM
Mindspin311
Yea, paint could wear away and cause things to become loose. Since there are the 2 holes for the locating pin, Im thinking a piece of steel machined to fit into those 2 holes, then over the studs on the top hat.
Those 2 holes for the locating pin could be use to locate off of. Then the nuts go on as normal.
Old Oct 11, 2012 | 08:01 AM
slinger688's Avatar
slinger688
Am thinking thru how that could work. Would you put a bolt/nut thru it? Are the pins still centered.
Old Oct 11, 2012 | 08:59 AM
Mindspin311
Hard to describe what I am thinking. I will take some pictures and put together something in CAD and post it up.
Im thinking using the 2 holes that the locating pin could be in as anchors.
Old Oct 11, 2012 | 04:18 PM
dboard7's Avatar
dboard7
I drive my car on the track about once a month in the summer and have not hade mine move at all that i can see
wildwestrider
Dec 27, 2015 08:20 PM
wesmc
R55 :: Clubman Talk (2008+)
Sep 28, 2015 12:07 PM
wildwestrider
Sep 4, 2015 06:25 AM
Suspension Products
Sep 3, 2015 09:41 AM
SneedSpeed
Sep 2, 2015 05:34 AM
